Question about Garden
Husqvarna clogging problems
Hi,I have a 19hp Husqvarna tractor clogging shoot problems in dry,shortish grass??
thanks!
WIll
    Scholar:
  • 108 Answers
Make sure your deck is scrapped out after every 8-10 mows, make sure your blades are sharp. I'm assuming you have a bagging system. Make sure you have the correct blades on your mower. Blades need to have a high wing in order to push the debris out correctly and make sure there are no other obstructions in shoot and always run engine at high rpm.
Posted on May 14, 2010
How to fix full grass box buzzer
Dirt over sensor perhaps
Aug 21, 2015 | Husqvarna Garden
Husqvarna yth24v48ls leaves streaks of uncut grass
What are the size of the streaks? and where in the 48 inch swath?
Aug 06, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Have husqvarna Lgt2654 riding mower
with a mower deck that large it needs to be a power bagging system cyclone rack etc
Apr 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
My 2 year old Husqvarna riding mower, with the welded steel deck, has the mulch kit installed ( I installed it). When cutting, the mower ususally leaves a thin line of uncut grass. More, when the grass...
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Sep 06, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Riding mover 42" deck, clogs
Wet and or excwssively high grass? Blades sharp?
Apr 21, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
After emptying the grass from the storage on the back of the rider, when I start to mow again, the grass that is in the catcher from the deck to where it shoots out, gets clogged and will not move on to...
Clean out your chute also and don't let the catcher get so filled up, check it for readiness to empty more often.Don't cut wet grass that tend to stick and cause trouble. Good Luck...709
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck clogs with grass, have to scrape deck after every mowing
mow when grass is dry,dont let grass get to tall.
Aug 16, 2009 | Garden
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Motor problem
Hello bartekzag:
From your Description it Sounds like Water in the Gas, Valve Clearances Require Setting or the carburetor Solenoid Requires Replacing.
>>If this is a New Mower and Under Warranty, then Return the Unit to the Dealer.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 18, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
73 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
