Question about HP LaserJet 2420 Printer
Smudge lines on left side of page - HP LaserJet 2420 Printer
  • 1,110 Answers
Only 2 possibilities. The most common cause and the easiest to check is the toner cartridge. If you have a spare just swap out the cartridge and try another print to see if it clears. If you do not have a spare take out the toner cartridge and turn it over. Open the gate that covers the drum and see if you see the same smudges on one side of the drum. If so then it is the cartridge as this drum should be clean.
If the drum is clean or a cartridge swap does not fix the problem then the problem is the fusing unit or more specifically the fuser film is bad. You will then need to do a fuser change or get a local person out to change the "fuser film" About $150 total if they do the film, about $300 if they do a fuser unit complete.
Good Luck and Thank You for using Fixya.
Posted on May 13, 2010
Scanning duplex I get a line down the righthand side of all alternate pages?
With very limited information, I suspect if you observe closely on the side that has the line printing you will find a dark smudge on the glass. If this is found you should be able to use a little rubbing alcohol on a clean cloth an remove the smudge.
Mar 28, 2016 | Fujitsu ScanSnap iX500 - document scanner
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
My HP LaserJet 2430n prints black smudge lines down the left side of the page. How can I correct this?
check the fusing unit in the rear of the printer and check your print cartridge for smudges.
Sep 28, 2009 | HP LaserJet 2430dtn Printer
Smudge on left side of paper
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Feb 04, 2009 | Ricoh Aficio CL3500N Laser Printer
Lines or smudges How do I fix?
Yes the image drum is the most likely cause, but it is unlikely you will be able to see the defect on it. Replace it
May 18, 2008 | Minolta magicolor 2300W Laser Printer
Ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
HP LaserJet 2420 Printer Logo
368 people viewed this question
Seeker5211
Seeker5211
