Question about Sony KP-53XBR45 53" Rear Projection Television
Sony 1997 KP-53XBR45
Great Sony projection TV that have owned since new. No problem till about 1 month ago the remote no longer operated the TV. I have another Sony unit and this same remote does work on that unit. Believe the problem must be in the front senor (or further down the chain). What should be my process from this point on to find the problem and fix?
  • 3,037 Answers
First open up the front panel after disconnecting the power, be careful since you can receive an electrical shock that is very dangerous, if you don't know what you are doing, then get a technician to work on it but basically you can replace the sensor and see if that fixes your problem, before replacing it, back track it and see if anything looks bad. If you need a service manual, I can point you to a site where it won't be free but can give you one. This service I don't think is online anywhere. Thank you and good luck and don't hesitate to ask for further help
Posted on Mar 29, 2008
    Genius:
  • 3,587 Answers
Well...the sensor is in side on a board that interfaces with the control board..are you technically adroit enough to open this up, without frying your self? Need to ask to ensure your personal safety
  • 59 Answers
You purchased this in 1997? Warranty on that model is only for 1 year, so you're going to have to pay for the repair...
and it looks like sony does not guarantee that they will sell you replacement parts or service for any longer that 2 years after purchase.
at this point, I'd say you'd have to look in the yellow pages for a television repair shop.
6ya staff
SOURCE:
My kds-r60xbr1 sony wega projection tv is blinking green then red and wont go on how do i fix this problem .i also just replaced the bulb about 3 months ago.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Batteries need changing about every 2-3 weeks !!
Three options
1. take out the batts, press every button twice and put new ones in
2.call logitech and see if they will replce it
3. take that baby back to the store and get a new one
Jan 24, 2009 | Logitech HARMONY 659 Remote Control
Remote no longer works after opening rear of TV
I think blowing air cleaned the TV but Remote Sensor at front of TV got more dusty and now unable to receive Infrared signal of remote. That's my theory and can be confirmed by cleaning of Remote Sensor in TV.
Regards,
Aug 25, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Remote Control
can i ask where did you buy ur tv?
Nov 08, 2007 | Batesias LM2010 20 in. LCD Television
Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
Oct 18, 2007 | Sony KP-53V85 53" Rear Projection...
Sony KP-53S35 Rear Projection TV
You will need to replace the "HA" board wich is the control panel and remote reciever (wich has failed). Here is a link to the part number and where to purchase from. http://www.partstore.com/Part/Sony/Sony/KP53S35/Sony/Sony/A1372288A/New.aspx
Apr 09, 2007 | Sony KP-53S35 53" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
