Question about OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer
Fax Result NG <1005> what is this? how to fix?
Where is exact location of low beam driver side fuse 2007 Sentra ?
HEADLAMP (FOR USA)
LT-21
C
D
E
F
G
H
I
J
L
M
A
B
LT
Revision: December 2006
2007 Sentra
8.
CHECK HEADLAMP CIRCUIT
1. Turn ignition switch OFF.
2. Disconnect IPDM E/R connector.
3. Check continuity between IPDM E/R harness connector (A) and
headlamp harness connector (B).
OK or NG
OK >> Replace IPDM E/R. Refer to
PG-30, "
Removal and
Installation of IPDM E/R
NG >> Repair harness or connector.
Headlamp Low Beam Does Not Illuminate (One Side)
EKS00JMQ
1.
HEADLAMP LOW BEAM FUSE INSPECTION
Inspect 15A fuse [No. 40 (LH) and No. 41 (RH) located in IPDM E/R].
OK or NG
OK >> GO TO 2.
Jan 27, 2016 | Cars & Trucks
How do I print a single call report for a FAX previously sent
Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
Jul 06, 2011 | HP LaserJet 3050 All-In-One Printer
We a incoming fax comming, we don't get fax but fax call report with "comm error 392"
Assuming you have an HP laserjet, you can either try again in a little bit or disable v.34 on your machine and use v.17 instead
Perform the following to turn V.34 off and access the lower speed of the local machine.
1. Press the ENTER/MENU button one time.
2. Press the or > button until the front display reads "Fax Setup".
3. Press the ENTER/MENU button.
4. Press the or > button until the front display reads "All Faxes".
5. Press the ENTER/MENU button.
6. Press the or > button until the front display reads "V.34".
7. Press the ENTER/MENU button.
8. Press the button until the front display reads "Off" and then press the ENTER/MENU button to save the setting.
Feb 28, 2011 | Office Equipment & Supplies
How to cheat crossfire
please teach me how to cheat
Feb 23, 2011 | Crossfire XP1000D Car Amp
The message prints out from my HP Officejet 7410: A communication error occurred during the transmission. Result Error 232* It was working fine before, now it won't fax 2 pages.
Actually Error 232 is mostly because of the Remote machine still we can try one thing in your machine ie - we can disable Error correction mode
How to disable it?
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
Try to send fax now .. It should work
Please Vote for me if it works
Jan 04, 2011 | HP OfficeJet 7410 All-In-One InkJet...
NG result
NG is just the error and not the problem, you have to read the code with the NG, it could be a phone line problem, a problem with the fax on the other end, a busy or not answered fax...any number of problems.
Oct 09, 2009 | Canon LaserCLASS Fax 710 Printer
Incompleter transmission causes? Result NG?
It means No Good. 5 possibilities:
Receiving machine unplugged
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Jul 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mf4150 -- fax has a mind of its own?
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Connecting Linksys wrtu54g wireless router with Linksys SPA 2102
If you want to receive "incoming" telephone-calls:
ADSL modem <---> Linksys SPA <---> wrtu54g <---> wired computer
and Linksys SPA <--- telephone-line-1 --> telephone hand-set
and Linksys SPA <--- telephone-line-2 --> FAX machine
or Linksys SPA <-- telephone-line-1 --> mechanical telephone-splitter
with telephone-splitter --> hand-set
with telephone-splitter --> FAX
Mar 19, 2009 | Linksys Wireless-G Broadband Router
OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer Logo
654 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
