Question about Canon PowerShot A520 Digital Camera
I cant get good pics at nite , i go to the races and carhshows , i need a book on it where can i find one
Cant post pics to face book
that can be due to your browser problem re-update your browser and this problem will be solved
Apr 16, 2017 | Facebook Computers & Internet
Replace front hub assembly 2002 Suzuki XL7
the front wheel bearing hub?
XL-7 (the dash matters)
my wild guess, is the questions was
what are all steps to do this job. and tools.
that?
RTM?
https://suzukipitstopplus.com/Products/10056-2002-grand-vitara-xl-7-service-manual.aspx
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
the link shows all years, and variances.
here is a photo review, that is accurate up to
1998, and beyond , if you skip the bearing service parts. as yours are INTEGRATED
and NON-serviceable.
the photo 6a and B
shows removing the hub,
so do that , buy a new hub and put it back
the same way, using the tool stated
at the stated ranges of torque
123-180 ft/lbs.
this range allows you to get the screws into the locking rings.
Dec 11, 2016 | 2002 Suzuki XL-7
I put a new sd card in it and its saying card full
I called Moultrie service earlier. My nite pics are non-existent. They recommended a new SD card,which might help you. Rec: Sandisk. Avoid " Ultra, High Speed,Dmpina, Mini, Micro, PNY, Max Flash, Extra flash, and Premium. The number @ Moultrie:800-653-3334. Good luck.
Aug 10, 2015 | Moultrie Game Spy A5 Trail Camera
How can I find a race track?
Racing your car on public roads is dangerous and illegal. You will also have a lot more fun on a track that is made for speed and safety. Not all of the countries allow racing so you will need to check if it is legal. If it does you should find it in a quick search on the internet or in a phone book.
Jan 10, 2013 | Motorsports
How to replace neck barrons
Remove tripple trees.you may need to use a bearing removal tool, check your races make shure they are good. replace bearings I heat up bearings in oven & put tripple tree in freezer over nite helps to install bearing..
Mar 28, 2011 | 2000 Harley Davidson FXST Softail Standard
I cant see any picture on face book why
Good day!set it as primary pic..
mastergani
Mar 21, 2010 | Computers & Internet
The flash on my CX7430 is too bright, the pics are too bright. This just started happening. Any clues?
Pls. adjust the ISO.
Use the nite SCN. (The feature often avoids the use of flash)
Swich the flash off. When doing this remember to hold the camera very still when taking the pics.
Nov 21, 2009 | Kodak EasyShare CX7430 Digital Camera
Took photos without memory card in - can I retrieve them?
Hi there
You should have a USB lead that goes from the camera to the PC, just connect them up and let the computer install the new hardware, once done if it doesn't autoplay just look in computer for "removable device" just double click on it to open the device and then copy the pics to the PC.
Good luck and thanks for using Fixya!!!
Feb 13, 2009 | Canon IXUS V2 Digital Camera
Good book for a beginner?
have you set it to macro mode? (little flower icon on the right cursor) this function will allow you to get within about 2cm of the subject, however do not use the zoom as the lens cannot focus close enough. To get results any closer you will be looking at an slr and a budget on a few thousand! If enabling macro and not using zoom to allow the lens to focus doesn't get you close enough in you can always enlarge and crop images. have a look on www.picture-skew.blogspot.com i've taken some macros of flowers and bugs, this camera can capture the hairs on an ants back or the individual lenses of a flys compound lens eye.
persevere with this camera, for a very small budget you will get amazing results, ISO refers to the speed of 'film', it comes from the dark old ages of 35mm film cameras. Basically a low ISO is the lowest sensitivity to light and gives the best image quality, however as the ccd is less responsive to the light the camera holds the shutter open for longer. The higher the ISO the more sensitive the ccd but the greater the noise and lower the quality of picture.
Books, try looking for more photography orientated books and less digital camera based books. An upto date photography book will tell you all the technical information about how to take a good picture for any given senario.
if you would like any further advice email me (address on the blogspot)
Dec 20, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Canon PowerShot A520 Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
