Question about Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw: DW7881 Worklight
I have a dewalt 788 scrollsaw. I use spiral blades most of the time. I got a new blade chuck for it and all it does is bend the blades. dewalt says they never heard of it, but sent me another chuck and it does the same. I change the screws, no change. I took it to a tool shop and that was a waste of time. i have been down for two months and cant solve the problem, can you help?
Email me with pics of your blade holders and explain more on where the blade is bending. pics will help. rca@pmt.org
Ray
Posted on Jun 15, 2010
Dewalt scroll saw model 788 drifts to left constantly
You've hit something (metal) and knocked the edge off of one side of the blade----replace blade it should be good---GL
Feb 26, 2017 | Dewalt Saws
It speeds up slows down all by it self while sawing speed set at 6.
This sounds like the motor may have an issue or the speed control trigger switch.
Oct 21, 2016 | Garden
How can I cut wood 3.5 inches thick with Dewalt Scroll saw?
nope... throat on scroll saw is of fixed height... beside, all scrollsaw blades are of fixed length, i would suggest use of bandsaw with very narrow blade with minimal kerf. do not use pressure on the blade! you will then have same cut through the thickness of the wood! setup bandsaw correctly, do not overtension it - see my other instructables pertaining to the bandsaw and regulation/setup of it
if you find my solution helpful - do not me shy... give some points... :-)
Jan 23, 2014 | Dewalt DW788 20" Variable-Speed Scroll Saw
My Dewalt 788 Scroll Saw table has a problem: It's fine when level, but when inclining the table left, it contacts the blade. That's when I noticed there's vertical play in the table; the
First: if there is looseness in the table, it is dangerous. So I would check all the parts for wear. If, for instance, a knob worked loose, the bolt could have worn (via vibrating) the bracket, resulting in you being unable to tighten it correctly. Occasionally I take mine all apart and check it all over for just that reason. I also check all the knobs just before use to make sure they are all tight. Here is a web page talking about Dewalt scroll saw problems and solutions http://www.scrollsaws.com/SawReviews/DewltTuneUp.htm
Jan 03, 2018 | Dewalt DW788 Heavy Duty 20" Variable Speed...
I bought a Dewalt DW310 reciprocating saw and there seems to be no way to install a blade. The instructions show a wheel to turn to unlock the blade chuck but the wheel is up inside the saw body where you...
The blade clamp collar is a spring loaded knob of sorts that holds the blade in place. If you are not able to pull the blade shaft out of the saw to get at it, plug the saw in and hit the on/off trigger a few times to get the shaft and knob out of the body of the saw. Once you can get at the knob it should be easy to turn it and insert a new blade. Let me know if you have problems.
Aug 30, 2010 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Blade not releasing
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Jul 05, 2010 | Dewalt DC385B 18v. Cordless Bare...
Can not replace blade on Dewalt 303 6.5amp
heatman101
May 23, 2010 | Dewalt DW303 Heavy Duty 65 Amp...
Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw:  DW7881 Worklight Logo
321 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
