Question about Samsung Televison & Video
I replaced the light bulb and the fan and now there is a buzzing noise in the front left hand side of the TV. It is on the lower left if you are look at the TV. Model HL-P6163W
  • pgendron May 13, 2010
    Thank you so much for your help, I cannot believe how fast you responded to my message.
    Thanks again
  • 10,594 Answers
That kind of sound would be coming out due to bad color wheel that is located next to lamp housing inside light engine.
Click Part Store to see an image of color wheel.
Let me know if you have additional question.
Thanks.
Posted on May 13, 2010
40 inch sony bravia making buzzing noises....any suggestions
There are 2 small 1.5" fans that are located on the top right and left sides of the screen. These fans are of the non ball bearing type, so the bearings may be wearing out. You can either replace the fan or add a couple drops of oil to it. Remove the label on the back of the fan and put the oil there, it should quiet down. This will work for a while but eventually the fan will need to be replaced.
Good Luck!
Rich Lilja
Feb 28, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Samsung hlp5063w dlp tv. 1- loud buzzing noise coming from the left side of the set (looking from the front). When I tap it the noise tends to go away and come back. So I'm thinking it's...
It is much more likely considering all these the wheel fails to be your issue.
The problem is often described as a fan like or high pitched sound which since the motor on the wheel turns at over 12,000 rpm is likely to be the cause.
Hint: most color wheels if you listen from the rear when the set is shut down the whine/fan noise instantly slows down until the wheel stops.
Eventually wheel will seize up and shatter and set will not come on.
Mar 18, 2012 | Samsung Televison & Video
My Samsung HLP4663W 46 in was making a buzzing noise for several months. I know it could have been either the fan(s) or the color wheel, but I never opened it up to determine which it was. Now the TV quit...
Great reasoning work! In fact, the lamp will not light if the color wheel does not spin-up. Fans will not stop the process of lamp ignition. Instead, a fan will be detected and a message will appear on the screen telling which fan has stopped. You need to have the color wheel replaced.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Power light blinks on 4 times then off
Have you replaced the lamp recently?
If so make sure the Lamp door is reinstalled correctly as a 4 blink error codes indicates Lamp door failure.
Dec 07, 2009 | Sony KDS55A2000 55" HDTV
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I saw your post about your HLP5063W
Click here to find information on how to replace the color wheel on your TV.
Good Luck.
Oct 28, 2008 | Televison & Video
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Buzzing sound by bulb
be quite sure that it is not the fan physically touching the case; other than that, scope your B+ voltage to the ballast and be certain it is clean;  while it could be that or the lamp itself, it is most probably loose or misaligned case assembley
Oct 09, 2007 | RCA D44LPW134 44" HDTV
Televison & Video Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
