Question about Schwinn 820 P Treadmill Silver Service Delivery
Schwinn 820 treadmill quit working in the middle of walk shows L-5 on screen. what is problem?
    President:
  • Schwinn Master
  • 832 Answers
Loss signal: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
Testimonial: "very helpful thanks much, JW"
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
How do you change walking belt on Epic View 550
Heidi, There will be quite a bit of disassembly required to remove belt, I have attached your manual, which shows an exploded view showing what has to be removed to access rollers and remove belt. you may get away with dissembling/remove front motor cover,remove rear roller and front roller.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/d/de84f386-3308-4d84-a2ed-a52898e55aa5.pdf
Treadmill Walking Belt Installation Video by Treadmill Doctor
How To Remove Replace Treadmill Belt and Deck Green Fitness Company
Jul 24, 2016 | Epic View 550 Treadmill
How do I fix error 3 on schwinn treadmill
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 25, 2015 | Schwinn 6100/6300 Walking Belt
Tripping breaker that is built in to treadmill
you must isolate the problem. See if there some loose cable or touching with chassis. 3) test the input terminal motor for to see if there are faulty 4) test the output terminal in the control board, for to determine if are faulty. 5) filter capacitor can be shorte 6) power supply shorted.
Nov 13, 2013 | Schwinn 820 P Treadmill Silver Service...
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
Schwinn belt stopped
Dear Sir:
1) You must LUBE the Deck Belt, in according with the instruction manual. The deck maybe is worn.
2) See if the deck belt is in bad condition.
3) Test the drive belt if o.k
4) Test the main motor if running, if not the motor need attention and repair.
5)Test the input voltage for motor coming from the main motor BOARD.
see my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Schwinn 820 P Treadmill Silver Service...
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
How do you adjust the slack on the belt? This is for a 815 model.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 04, 2010 | Schwinn 820 P Treadmill Silver Service...
Schwinn 820 P Treadmill  Silver Service Delivery Logo
700 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
