Question about Acer Aspire E380 ASE380-UD500A PC Desktop
The BIOS startup time is 5-10 minutes, showing
The BIOS startup time is 5-10 minutes, showing "Del setup, F12 for boot sequence change" while no keys work.
It will then finish on it's own showing no further problems.
No changes to the BIOS have been made.
    Problem Solver:
  • 12 Answers
Either you have failing hardware attached or bios is looking for a device (probably a drive) that is not present.
Posted on May 14, 2010
Computer showing missing boot manager
1-Insert the Windows installation disc into the disc drive, and then start the computer.
2-Press a key when the message Press any key to boot from CD or DVD appears.
a-If your PC does not detect the media automatically
b-During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
c-Look for a tab in the BIOS Setup Utility that is labeled Boot Order, Boot Options, or Boot. Following the directions on the screen, use the arrow keys to go to the Boot Order, then press Enter.
d-Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
e-Press F10 to save your changes and to exit the BIOS Setup Utility. Select Yes in the confirmation window. The PC will restart.
3-Select a language, a time and a currency, a keyboard or input method, and then select Next.
4-Select Repair your computer.
5-In the System Recovery Options dialog box, select the drive of your Windows installation, and then select Next.
6-At the System Recovery Options dialog box, select Repair your computer.
7-Select the operating system that you want to repair, and then select Next.
8-In the System Recovery Options dialog box, select Startup Repair.
http://bit.ly/2ykOBno
Oct 13, 2017 | Computers & Internet
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
How can i change boot sequence of my desktop
You have to change the boot order at the bios settings. Just after the screen comes up, before windows start up press (repeatly) the F2 key (depending on the model, maybe F1 or del key) and go to the boot sequence. Here change the boot order as you wish.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Mar 15, 2011 | IBM Lenovo ThinkCentre M55e PC Desktop
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
How to change boot for cd or hd
That is done in the bios.
you could also watch the boot sequencs and see if it says somthing along the lines "press F10 to change boot order"if so that is another option
If this info was useful please click
Aug 13, 2009 | Toshiba Satellite 2400-S251 Notebook
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Setting boot sequence
press Del or F2 or Esc while booting ..
Feb 17, 2009 | Systemax ™ Mission Xeon™...
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Getting ERROR FOR OPERATING SYSTEM
This is because you have to change the boot sequence in the BIOS or setup of the motherboard. When you first turn on the computer you can see something like press DEL to enter Setup or F12 or F10 or F2 depending onyour motherboard. once you get into setup you will see either boot sequence or boot order. Set the CDROM as the first boot device. Then when you startup the computer again you will see PRESS ANY KEY TO BOOT FROM CD. proceed with pressing anything on the keyboard.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Boot from cd
when u power up the computer press DEL or F2 or F10 F12 key to enter bios setup.
then go to boot option then set your dvd or cd as first boot device.
Nov 30, 2008 | Intel Motherboard
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
