Question about Nikon COOLPIX S200 Digital Camera
My camera stopped saving pictures to my memory card. It seems as if I am taking a picture, but when i go to view it it isn't there! I have tried multiple memory cards to be sure that it is the camera and not the memory card... it is the camera.
    Brigadier General:
  • 11,967 Answers
With no card in the camera, try to view the pics. If they show up, they are being stored in the internal memory. It must be formatted to completely erase it before the camera will start saving to the memory card.
Posted on May 13, 2010
2 Suggested Answers
moeshere
  • 33 Answers
SOURCE: Transfer of photos on camera without memory card to memory card
take out the memory card and plug the camera to your computer and it should show that way and save them. hope that helps..
Posted on Apr 05, 2009
Don't know how to set up my camera to take pictues
turn the camera on with the button on top, then take off the lens cap and insert a memory card into the side. The pictures will save to the memory card and you can buy an adapter to connect the memory card to your computer to view and save the pictures.
Jul 03, 2011 | Casio QV-R40 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
My dsc-w80 keeps saving all of my pics to the internal memory
Set camera on playback mode, you will see any saved picture in internal memory. Insert memory card and lcd screen will show you either blue screen if memory card has no picture files or will show you picture in memory card. That means memory card is intact with camera and ready to store fresh picture.
Set camera to camera mode and take few fresh pictures and check them in playback mode.
Let me know if you have additional question.
Thanks.
Jul 20, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
I took pictures without a card. How do I view them?
You can try connecting it to your computer via the usb cable...
Jun 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Take pictures but not saved so i have no pictures on my camera
The only way this could happen is if there's no memory card in the camera.
Easiest solution is to take the camera with you to Best Buy, hand it to someone in the digital camera department, and ask them for a compatible memory card.  They'll most likely respond asking you how many pictures you want to store on it.  You'll respond accordingly, hand him/her a debit/credit card, and be on your way.
Mar 18, 2009 | Canon PowerShot A570 IS Digital Camera
Incompatible jpeg
Hi there
Save all the pictures to the computer, then format both cards using the menu in the camera, then take a picture and see if it takes them well.
Good luck and thanks for using Fixya!!!!
Feb 19, 2009 | Canon PowerShot SD1100 IS Digital Camera
Image problems - samsung L100
You can try a different memory card, but I don't think the problem is memory card, if pictures look scrambled, and colors and brightness are not uniform, that is either a problem with CCD sensor (optic sensor that takes the picture), or logic board.
In either case, this is not an easy repair.
Reset the camera to default settings from camera menu, and try a different memory card, but the camera will probably need to be sent in for repairs.
Jan 02, 2009 | Samsung L100 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Samsung s370
I'm willing to help you out on this.
Basically, there is no settings for picture storage on your camera.
Once you took pictures WITHOUT a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures WITH a memory card, all pictures are just saved on the memory card itself.
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
- Turn on camera
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
70 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
