Question about Kenmore 24032\24036 Top Load Washer
Kenmore model # 20722990
After the rinse cycle there should be a 3 min drain cycle that does not come on then the timer stops it might be 10 min or 3 hours it will start on it own and finish drainig and finish the cycle. Im thinking relay but I not sure which one does what. Iam a mechanic and do have a D.V.O.M I have a kenmore model # 20722990
  • Anonymous May 17, 2009
    Cycle runs, but as soon as it is suppose to drain it stops, unfortunately I am not patient enough to see if it automatically starts again at some point.
  • 26 Answers
It sounds more like the timer motor is stopping. There mght be something binding or a dead spot on the motor.The next time it does that, advance the timer slightly a few times and see if it then advances on it's own Check all the wires, too. Take the timer assembly out and flush it several times with alcohol or plastic safe electronics cleaner while operating the timer (engaged) several times.
Posted on Mar 30, 2008
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Kenmore model 110-20722990 stops mid-way through the rinse cycle full of water. The lid switch is tight and intact to the best I can determine. The machine just stops mid-way through the rinse cycle...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
The first thing I'd do is try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using a short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Beyond that, I'd use the troubleshooting section of the Service Manual to test the timer. First though, I'd try it on a different cycle.
Jul 27, 2010 | Kenmore 20722
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
Jan 19, 2010 | Kenmore Washing Machines
Washing machine Series 80 Kenmore wont drain water after it's RINSE cylce including the motor. It's like the TIMER stopped after the RINSE CYCLE. I think it's the timer.
does it drain after the wash cycle? if it does, then I don't think it's the timer. It uses the same contact there as for the rinse cycle. Do you hear the motor running as if it's trying to drain? If the motor is running, perhaps the pump itself is no good? Just a couple things to check. Hope it helps.
Joe
Sep 05, 2009 | Kenmore Washing Machines
Washer stops during rinse cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2009 | Kenmore 20722
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
Kenmore 24032\24036 Top Load Washer Logo
346 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
