Question about Philips cBright XG2 Multimedia Projector
I got a dell 2300 mp projector and hp pavilion dv4-2145dx eny notebook and all it does is blink off and on like theres a short but every body elses computers hook up fine
Dell 2300 MP turns on and the lamp turns on, but then the tempera
Ok you need to replace the thermo sensor on this now the thing is the replacment is not something "just anyone can do" Now what you can do is this you can take it into BEST BUY witch are EXPERTS to help you replace the sensor in this.
But for a end user to dig inside of this would not be wise. I would highly recommend a expert fix this due to the sensor. The sensor is on the ballast board.
I hope this FREE answer helps please do vote on it anyways and leave some feedback for us today!
Mar 05, 2010 | Dell 2300MP Multimedia Projector
Dell 2300 MP temp light flashes and projector turns off.
I am experiencing a similar problem with mine. It will cycle on and off without actually powering up fully and then after about the 4th or 5th time it will shut off completely and the lamp indicator light on top illuminates. i am reading in other blogs that this is a design flaw on this unit. let me know if you have found any fixes.
Jan 31, 2010 | Dell 2300MP Multimedia Projector
My fans left and right work but not the middle does not
its bad go to newegg.com or eny pc store eny fan will work long as its the same size.. there cheep
Oct 06, 2009 | HP Pavilion zd8000 Notebook
Configuring 2300 Wireless Broadband Router with new HP Pavilion
Yes.
Just ensure you configure your new HP pc with the same security code and password you used on your old Dell.
Dec 28, 2008 | Dell TrueMobile 2300 Wireless Broadband...
How to connect Hp pavilion dv2000 to a projector
We need more information please. How are you connecting the projector? What do you see on screen?
Have you tried switching it over using the function keys? One of them will have a symbol of a square inside a square press the function key and this one.
Aug 20, 2008 | Dell Latitude D600 Notebook
HP Pavilion Dv2000
on your display properties, switch windows to appear on your laptop. and do not connect your LCD when booting your PC. there is an option in display property that says extened your windows to this display... that is your LCD.
Apr 10, 2008 | Acer TravelMate 2300 Notebook
Color wheel
Hi there
Simply locate your nearest Dell dealer and give them a call.
Apr 02, 2008 | Dell 2200MP Multimedia Projector
Dell 2300MP shows no connection after 15 min of work
that's a clear indication that you have a major heating issue inside the box..the internals are apparently overheating, as it will work after cooling down, right?
Mar 07, 2008 | Dell 2300MP Multimedia Projector
2300 mp stays on for only 3 minutes then turns off
ok..try to long press the power button to refresh the settings..
Jan 28, 2008 | Dell 2300MP Multimedia Projector
Dropped signal
Have you tried changing the display to clone the image?
Nov 23, 2007 | Dell 2300MP Multimedia Projector
Philips cBright XG2 Multimedia Projector Logo
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
