Question about Waterway 1hp HiFlo Pump Wet End
I have a Waterway Wetpump 1 HP for my 10,000 gallon above ground pool. Its not working, but when its plugged in, it moans like a plugged garbage dispsoal. Maybe its clogged? Is there a way to test the motor, open it and clean it out or a part out?
    President:
  • Waterway Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The motor is likely failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on May 13, 2010
Testimonial: "Excellent feedback !"
I just got a 2hp Waterway 48 hiflo pump. The discharge is facing up can it be rotated to the side or is it fixed?
There a four bolts that run through the motor into the wet end, or pump. Use a 1/4" nut driver and loosen the bolts until they are free of the wet end, then you can rotate the wet end so the discharge is face to the side. Tighten the bolts and your done.
Sep 07, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
How to change bearings on pump 1 hp above ground
Changing bearings in a pump motor is not something the average handyman will do. It takes some knowledge and some special tools to do this correctly. You would be better off buying a whole new pump, or replacing the motor on your present pump.
Sep 14, 2011 | Waterway 1 HP HiFlo Above Ground Pool Pump
I have a proline de 1.5 hp above ground pool filter. How much de do I put in the filter? Thanks
one pound of D.E. for every 10 square feet of filter area, there should be a data plate on the filter telling you what the filter area is.
Jul 30, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
Model #SD-20-2N11CC WATERWAY PUMP (2HP) - Trying to find out how many gallons per minutes pumped on high & low speeds
Rule of thumb for a 2 HP pump using a 2 inch pipe is between 60 and 80 gallons per minute. Factors affecting flow rate is the distance between the pump and the pool, how many bends and turns and of course the condition of the filter. If you need to meet a specific turn-over rate, use the lower number to determine in the event you sould be called on the carpet.
Low speed? I am sorry. I don't know the rule of thumb on this.
You could install a flow meter, available at your professional pool supply. They are easy to install and not a lot of money. Follow the installation instructions as best as you can.
Incidently, comercially speaking, the 'turn over rate' should be around 8 hours for a public pool. Your jurisdiction may have other standards. Commercial pools should run 24 hours a day at that rate during the open season. Turn over rate means all the gallons of the pool should go through the filter in 8 hours, or all the gallons should go through the filter three times per day. Example: 16000 gallons of water in the pool, your filter and pump should be pumping 2000 gallons per hour. Studies show that it actually takes up to 5 days to get every actual 'chunk' of water to go through the filter, so, many of the 'chunks' of water go through the filter multiple times per hour. BTW, I use the word "chunks" in an effort to better paint a mental picture of what is happening. I am not suggesting your water has "chunks" in it.
Thanks for your question @ FixYa.com
Jul 07, 2011 | Waterway 2hp Hi - Flo 2 Speed Above Ground...
I have a Waterway Hiflo 2hp and lately is kind of loud. Do they need like oil or some kind of maintenance? Thanks
More often that not you probally had a leaking seal and the water is causing the bearing to rust and make noise. At this point you will need to have the motor rebearingd or get a new motor. depending on the age and condition of the one you have.
Sep 04, 2010 | Waterway 1 HP HiFlo Above Ground Pool Pump
Can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Apr 10, 2010 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Waterway 1hp HiFlo Pump Wet End Logo
130 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
