Question about Kenmore HE2 Plus Front Load Washer
My kenmore front load he washer is sticking on cycles ,it sticks on rinse and just keeps pumping water and if i move it to spin it punps the water out but doesnt spin any idea whats wrong thanks
    Top Expert:
  • Kenmore Master
  • 79,077 Answers
Does it go through the wash cycle, what is the model number of the washer?
Posted on May 13, 2010
  • 9 more comments
  • eddie_sparks May 13, 2010
    the model # is 417.44102300 it use to just freeze @ the end on final rinse and spin and the last cople times we tried to use it, it went through the wash cycle and froze on rinse and after that it just freezes on any cycle and the spin wont even start manually now,i took out the pump and it didnt look dirty or clogged had a couple quarters in the flex boot but thats it
  • yadayada
    yadayada May 13, 2010
    do u have any fault codes showing in the washer digital display? if so what are they.
  • yadayada
    there are really only 2 things that cause this problem, one is the washer control board, the other is the motor control board, my guess would be the main control (that is the display and buttons) is defective. does the washer drum move freely? Please take the time to answer each question as clearly as u can. thanks
    yes the drum spins freely
  • yadayada
    since there is no 100 for sure way to know if the motor control board or the motor control board is at fau;lt this comes down to a eduacated guess that the problem is the CPU, this is the main circuit that u use to set cycles
  • yadayada
    please also read this link, do u think u may has missed something as far as the drain being clear goes?
    http://www.fixya.com/support/t139129-ken...
    ok i was going mostly on my wife telling me how it was doing so i decided to go out and do an evaluation myself ,i started by removing the pumpand hoses and made sure there were no blockages and there wasn,t,, i also didnt see a filter on mine ,it looks as though this washer has been worked on before by the way the screw heads had wear on them, after putting it all back together i started the machine on reagular wash ,it began filling with water and stopped shortly after starting, the timer never moved ,so i advanced it each notch after waiting a few minutes and it not changing itself,,all it would do was pump water in and pump water out but never aggitated or spin does this help a little with what you need
  • yadayada
    You need a timer almost for sure, let me look it up.
    ohh and mine doesnt have a digital display either ,i got this set from my mother when she moved so all i have is the model # i had to guess the series ,my mother is on her way here and i might be able to get a lil more info then
  • yadayada
    I think u will need to replace this part, go to the link below.
    http://www.repairclinic.com/SSPartDetail...
    the part comes with install instructions.
  • yadayada
    If I have been helpful please rate me as "HELPFUL", THANKS!
Kenmore HE2plus model 110.47512603 shows F20 error code. I have replaced the pressure switch and the pump motor and assembly. I have also ensured that there is no siphon issue. I have also blown through...
f20 is a water problem,shut off the house water valve,mark the hoses and remove them from the back of washer,stick them into the washer or a bucket and open the valve,if water comes out strong then you have a bad water valve on the washer part WP8540751
Dec 16, 2017 | Kenmore Washing Machines
Washer will not complete full cycle and is holding water in the basket?
What part of the cycle is the washer sticking on? It sounds like you either have a timer problem or possibly a water valve problem. There is even a chance that it's the lid switch not allowing the washer to spin water out.
Does it go into spin ever? If so, does it stop at the rinse cycle every time?
Let me know and I'll help you diagnose further.
Cheers
Oct 06, 2010 | Kenmore 24902 Top Load Washer
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
likely the lid switch is bad - if not the ECU/timer is.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 43042 Front Load Washer
The machine when it is on a cycle sticks on the rinse spin
hi..most likely the timer switch which might have got
into trouble,this controls all the different cycles.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Neptune washer won't drain
pump ,could be blocked or could have failed.i have same model and have had to replace it.to be sure get volt meter stick meter probes into pump wires turn washer to pump out[around spin area]if voltage but no drain yes need punp or clean out.u can get to it from the back.God bless,tom
Dec 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water wont leave the machine in rinse or spin cycle
Sounds like you have a broken lid switch, most likely part # 3949247,,#11 on diagram. Dave www.washermd.com
Dec 08, 2008 | Kenmore 22422 Top Load Washer
Will not advance to the rinse and spin cycles...
The buzzing can only be that the pump if sticking or the inlet valve is sticking, other than that it is lack of water supply. Regards Advisor
Aug 23, 2007 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore HE2 Plus Front Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
