Question about Car Audio & Video
1996 dodge neon starts and then cuts off - Car Audio & Video
  • 1,284 Answers
Hi, a friend of mine had similar problem with 97 Plymouth Neon. It turn out that the Crank Shaft Position Sensor was failing, since he replaced it the car has been running smooth with no problems.
Take care
Posted on May 13, 2010
Location of cranksensor
Hi Margaret, The link below is a youtube video showing how to replace a crank sensor on a 1997 dodge neon, I know it's not a 1996 BUT motor should be the same, I hope this helps....... CHEERS..
1997 Dodge Neon no start crank sensor problems
Apr 29, 2016 | 1996 Dodge Neon
My 96 dodge neon wont start i change the coil but still did not
Change the cam sensor. I had the same problem you did and once i change this little sensor, car started right up!
Feb 28, 2010 | 1996 Dodge Neon
Change a water pump on a dodge neon
i need a diagrm for the cooling system on a 1999 dodge neon
Nov 09, 2009 | 1996 Dodge Neon
1996 Dodge Neon standard 2.0 It will start!!
Check your fuel pressure, What you discribed are symptoms of a faulty fuel pump.....Check your pressure when it is wanting to start and when it doesnt want to start......see if there is avariation...If not pop the hood when it is dark and see if you can see a light show under your hood...if you can then you have bad wires or a faulty coil/cap or rotor
Oct 07, 2009 | 1998 Dodge Neon
2000 Dodge Neon cutting out
This sounds like the symptoms of a choke being left on, but of course you have a fuel injected car. Could it be a computer problem, too much fuel getting to the engine?
Oct 06, 2009 | 1996 Dodge Neon
1996 dodge wont start keeps draing batteries
sounds like an alternater problem. the batt is not charging and is only running off the batt untill it runs out. check the wires ect on the alt and if that doesnt work, get a salvaged alt.
Aug 18, 2009 | 1996 Dodge Neon
Sorry where is the fuel filter on a 1996 dodge neon also my car cuts off while driving down the road what could it be
The fuel filter is under the car next to the gas tank on the passenger side
and with it shutting off could be all different types of reasons such as fuel pump,fuel filter,fuel injectors
Jul 07, 2009 | 1996 Dodge Neon
2004 neon drives normal then say I stop a light and vibrates, try to steer and it cuts out
I'd pull I.A.C. motor off and clean the pintle (pointed part) & shaft as well as port it comes out of, with throttle body spray cleaner, re-install & try it. If it cures it for a while, then starts to act up again, replace the I.A.C. motor.
May 17, 2009 | 1996 Dodge Neon
Find the pcv valve on a dodge neon 1996
When facing the engine compartment, the pcv valve will be located on the right end of the valve cover. It threads into the cover and will have a rubber hose attached also.
Any further problems, give me a shout.
Nov 19, 2008 | 1996 Dodge Neon
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
