My laptop wont load it just keeps coming up check cable fast ethernet controller v.2.13 what does this mean and how do i get my laptop back to normal so i can use it
  • 55 Answers
Go to bios, check boot menu to check if the primary boot is HDD, i believe LAN ethernet is set to priority, if it is, change it back to HDD(harddisk). then save and exit
Posted on Jun 11, 2010
Old Toshiba laptop displaying thisessage after it
I believe the Realtek controller is for the cable that plugs into a cable modem or DSL modem. Low connectivity normally applies to a wireless connection, not a wired one. Pleas let me know if you have any more questions.
Oct 06, 2014 | Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
Cant watch at higher rate. you tube keeps stopping
If you can't watch at a higher rate it means that your internet connection is not fast enough to buffer/load all the information contained in the video quickly enough to play it in a smooth fashion. Use 240p or 360p, this will reduce the amount of time taken to buffer/load the video.
Another approach would be to consider the purchase of a faster internet connection, or may be if you are using a wireless connection, connect your computer/laptop to your router via an ethernet cable when wanting to watch videos. Ethernet cable would be faster especially over long distances.
Take care!
damnor01
Oct 10, 2011 | Dell Inspiron 530 Desktop Computer
I have a Qosmio X305-Q705 laptop. It worked fine the last time I used it. Now when I turn it on the message that keeps scrolling is:For Realtex RTL8111B/8111C Gigabit Ethernet Controller v2.17 (080602), ...
click start control panel admistrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-96337.htmlRealtek RTL8139/810x Family Fast Ethernet NIC:It is a highly integrated and cost-effective single-chip Fast Ethernet controller. It is enhanced with an ACPI (Advanced Configuration Power Interface) management function for PCI/Mini-PCI/Cardbus in order to provide efficient power management for advanced operating systems with OSPM (Operating System Directed Power Management). The RTL8139C(L) also provides a remote wake-up function by Magic Packet & Wake-up Frame to increase cost-efficiency in network maintenance and management. Furthermore, it supports the Cardbus interface for PC Card applications and is an ideal solution for notebook / motherboard-embedded network design.
hope this helps
May 30, 2011 | Computers & Internet
No bootable CD in ATAPI CD-ROM Intel UNDI, PXE-2.0 (BUILT 082) copyrighr (c) 1997-2000 Intel coperation For realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v.2 13 (0203326) PXE-EGI: media...
try downloading from here
http://pci-ven.com/driverdetector/realtek/rtl8139realtek/realtek-rtl8139-x-8130-810x-pci-fast-ethernet-controller-v2-17-051202-.html
good luck
Nov 08, 2010 | Acer Aspire 5100 Notebook
Downloaded The Recovery CD's Went To Boot Up Laptop, Realtek Fast Ethernet Network Atdapter come's Up, Then Media Test Failure,Check Cable. Keep's Repeating, Even When I Shut It Down & Reboot It.
Hello sir, hi, this error could be several, so check this one by one:
  1. make sure your pc boots on the hard drive, not floppy, or other boot devices.
  2. If you are setting up windows boot from the CD drive.
  3. check your HARD DRIVE, this may be due to failure, format it using a low level format utility like disk manager.
  4. re-seat Hard Drive cables. use another cable if necessary.
Sep 16, 2010 | Toshiba Satellite A205-S5879 Laptop
My Acer Aspire 5100 keeps rebooting. This is what the screen says: INTEL UMDI PXE2 REALTEK RTL8139 PCI FAST ETHERNET CONTROLLER PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F: EXITING PXE ROM That is all...
The error message means that your system is trying to boot from LAN ie... Network boot enabled in your BIOS.
Since the system can't find any where to boot from. It is restarting.
Also probably your bootloader on the harddrive is corrupt. Please reinstall the operating system using a CD/DVD.
Jul 11, 2010 | Acer Aspire 5100 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
My notebook stop booting up it is saying.
unplug all the cables connected to the laptop.The moment u torn on the comp keep on tap the key F8 on the keyboard.try the options like last known good configuration,safe mode. i believe it will work after that boot your computer normally. if it doesn't we need look the BIOS settings. for that it is advisable to take your laptop to the service station..
Aug 20, 2009 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
