Question about iLO (2 GB) MP3 Player
HELP WHENEVER I PLUG MY MP3 PLAYER IN MY CPU IT DOES'NT READ IT AND WINDOWS
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Tip3 player is'nt downloading music from my windows media player!...why?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 10, 2012 | Audio Players & Recorders
Computer won't read mp3 player
press the + for a couple sec then it a wizurd should pop that should work
Sep 27, 2008 | SanDisk Sansa MP3 Player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Sep 05, 2008 | Audio Players & Recorders
I am going to assume that you have read my FAQ on Sansa players. If not, I will reprint it below. I had one in particular with which all of the below methods had failed - I simply plugged it into another computer - other than the original, and presto! it came back to life again!
-Tha Mp3 Doctor
Sep 03, 2008 | SanDisk Sansa Clip MP3 Player
Mp3 player
hello:
My mp3 player is creating a problem in deleting and saving songs from memory.. Whenever i tried to delete any existing file,, it deletes its once..but when i reopen. i find the same file in the library.. And when i tried to load anything in it..it stop in the middle of downloading..
I m nt getting where is the problem ? I tried to delete whole files from my mp3 players but some fles are nt getting deleted..Can anyone help me in this matter please ?
Jan 21, 2008 | iLO MP3 Player
RCA M4018 8GB MP3 Player
does it have to have a usb mode turned on or somtin
Jan 19, 2008 | RCA OPAL M4001 MP3 Player
Can iriver H10 run on Windows NT?
The easiest way to do this would be to shut the player off completely (remove the battery or push the reset button), plug it into your computer, then press and hold the OK button as you turn it on. This will cause your computer to recognize it as an external drive, and you can copy music to it via My Computer.
Dec 22, 2007 | iRiver H10 MP3 Player
Sandisk Sansa e270 MP3
Are you trying to transfer songs using windows media player?
Aug 22, 2007 | SanDisk Sansa e200 MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
