Question about Dryers
This is the fith time i have typed the same problem ... my dryer tumbles and the heating element is fine vents are clear but takes 4 hours and still not dry on a very small load
    Top Expert:
  • Dryers Master
  • 80,562 Answers
Do not keep posting the same problem over and over, go back to the original question and answer whatever the expert asked you or the expert requested more information, to use the link to reply to the orig expert on the 1st posting of the problem go to the top right of this page and click on the My Profile link, then in the next page scrool down to the bottom right and find the My Problems list, click on the 1st post and continue to talk with the original expert.
Posted on May 13, 2010
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Tumble Dryer intermittent squeal, then stopped heating, now black soot underneath
Dryers are susceptible to lint fires in their exhaust vents. You should be checking the exhaust vent at least once a year and clearing any blockages. If the exhaust vent becomes blocked, the dryer will heat up significantly and the lint could catch fire if there is enough heat build-up. If you don't clear the exhaust this will almost certainly happen.
Fire needs a source of heat (red hot heating elements), fuel (lint) and oxygen (the exhaust fan blows air at the blockage).
You should be able to replace the burned out heating element if you are comfortable doing the wiring. You can pay a repairman if you like but wiring is only so much common sense. Photograph the wiring before you start for a post repair check. Replace the element and any burned wires. Make sure the connections are tight and that there are no loose wires. Only the ground wire should be bare.
A Dryer uses 220V AC (in North America) like a stove and some water heaters. This is enough voltage to kill even hardy souls who laugh at 110V (usually enough to kill but not guaranteed to).
When you check the vent, check that it has some sort of safety rating. Not all flexible vent is fire-resistant. This scared me when I saw it on YouTube or somewhere.
Why did your smoke detector not go off when the element melted?Good thing to know if your utility charges less for power in off-peak hours. My mother often runs hers at night when the rate is very low.
My dryer runs from sunrise to sunset but we use an electric one in the winter months.
Sep 20, 2012 | Indesit IS70C Electric Dryer
Whirpool dryer takes 3 hours to dry jeans or towels.
Most likely your heating element has partially failed. Some dryers have two separate resistance heaters in them. If one fails what you are describing can happen. If you have the tools and are willing to take it in it's not that bad a job. You have to take the cover off the dryer to see it, then it is two bolts. Any appliance repairman can handle this easily.
Mar 22, 2010 | Whirlpool LER5636P Electric Dryer
Laundry not getting dry
Vent
Heating element
Internal ductwork
Cycling thermostat
Jul 18, 2009 | Dryers
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
Vent
Heating element
Internal ductwork
Cycling thermostat
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
May 20, 2009 | Dryers
We have a Kenmore 110 6092299 90 Series dryer. The motor still runs - but no hot air, at all. I've tried timed and heat dry. Nothing. It just tumbles and it takes 4-5 rounds to dry. At first we were told...
Sounds like the heating element or the thermo-cut off. A vent being clogged for some time, can cause too much heat to build up and make the element or cut off fail. These are the 2 most common things.
May 05, 2009 | Kenmore 63942 Dryer
Dryer not heating up
Could be the heating element?
Jan 12, 2009 | Dryers
Dryer heats slowly
When dryer heats too slow, that means that there is a problem either with the heating element, the thermostat, or the vent.
See the following suggeations from Repairclinic:
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Oct 04, 2008 | Whirlpool Dryers
Dryers Logo
13 people viewed this question
Top Dryers Experts
