Question about Dometic Rooftop RV Air Conditioner
I have a 15K BTU RV AC and would like to know the Wattage or amperage that it takes to run it. I do not have a manuel
    Novelist:
  • 135 Answers
The information that you want, all of it is on the manufactures tag on the unit.
Posted on May 13, 2010
How do I Wire a duo-therm RV heat pump
see wiring on panel make sure dip switches correct
Feb 26, 2015 | Dometic 459196 Duo-Therm Brisk Air...
I have a Dometic 15K roof Ac on my FW. After the AC reaches therm temp, the compressor and the fan turn off, but the fan starts right back up again and runs until you set the thermostat on off.
That is normal operation, only the compressor cycles, the fan stays running to keep air circulating for better temp control. Otherwise the rear of the space could get 5 degrees warmer than the front
Feb 23, 2015 | Dometic 459516 459516.XX1C0 Brisk Air...
What is the wattage of a 6000 btu ac unit
WATTAGE VARIES , START UP 3X WHAT RUN IS BUT A 20 AMP CIRCUIT SHOULD HANDLE FINE , CODE RECOMMENDS A LONE CIRCUIT FOR AC UNITS ANYWAY , BUT IF YOU WANT A GUESS AROUND 12 AMPS X 120 VOLTS =1440 WATTS GUESS MANY VARIABLES .
Aug 17, 2014 | Heating & Cooling
AC surge current?
you are missing the voltage supply here to get an definitive answer
for 240 volts drawing 4.8 amps the required wattage is 1152
for 120 volts the wattage is 576 watts
for 120 volts with a current of 900 watts , it equates to 7.5 amps
with 240 volts with a current of 1150 watts , it equates to 4.79 amps
so you can see the problem by not stating the supply voltage
get access to an cable clamp amp meter / watt meter from an electrician and read the current on starting the ac unit
if it exceeds 900 watts for 120 volts or 1150 for 240 volts , consider a bigger generator
Aug 31, 2017 | Fixya.com Heating & Cooling
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
Jun 25, 2013 | Dometic Rooftop RV Air Conditioner
I have 2 15000 BTU A/C units run to a double pole 20 amp each breaker. The breaker keeps over heating and one side will trip. Should i separate the units on their own breaker? The units cool and run fine...
That would work, if for no other reason, to isolate which one may be drawing too much/more amperage. Keep in mind as well, after a breaker trips too many times, it usually will get weak and trip at lower amperage. If all is same, ( wiring from AC units) and units are cleaned regularily and no other internal problems such as weak, bad, capacitors etc, they should both draw same or close to same. If possible that someone has a multimeter with amp draw clamp, that would confirm where trouble is.
Aug 09, 2011 | Dometic Rooftop RV Air Conditioner
Want to know the wattage of my kenmore coldspot model# 106 41512100
To determine the wattage take the voltage and multiply it by the total amperage.
The total amperage is usually listed where the model number is listed.
WATTAGE = VOLTAGE X AMPERAGE
EXAMPLE: 120 VOLTS X 9.5 AMPS = 1140 WATTS
Mar 06, 2011 | Kenmore Refrigerators
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
134 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
