Question about DeLonghi Ovens
I have a Delonghi Ess602 the main oven not working. The fan still works but no heat any ideas. When it stopped working it cut out all my electrics thought it was still working as could here fan and see light.
2 Suggested Answers
  • 833 Answers
SOURCE: DeLonghi doubleoven electric cooker ESS602
It is hard to know exactly from here. I'd suspect the heater element is open before anything else. If you can get to the terminals of the element itself (unit unplugged!, element disconnected on at least one side), then test for resistance with an ohm meter...available at any electronics shop or large retailer like Radio Shack, Sears Hardware or the Depot.
If there is none, the element is bad...hint: defective elements often have an area on them that is discolored differently from other parts. Food particles, particularly grease splash, will cause burnout. Terminals or connectors that are loose or corroded will cause non-function or failure. Look for those issues. Make sure all connections are tight when you're finished.
Posted on Jun 16, 2008
I have a Bush AE56DA electric oven, the main oven has stopped heating up. Also the oven light and thermostat light have stopped working. Everything else works fine. Any idea's? Thanks.
This sounds like a regulator problem, now there are the switch or a built in behind the cooker. WARNING DO NOT OPEN ANY PART OF THE OVEN ISOLATE THE MAINS FIRST.
You will need a tester, multi-meter would do. check the switch for continuity check the heating element there may be a hole in it, its very difficult to see slight Gray Colour just at the hole, find and inspect the fan motor if there is no continuity after disconnection of wiring between the winding terminals, on most models you have to remove the fan before you can inspect the heating element, but there are a few the other way round. Hope this is helpful .
Regards
John
Nov 02, 2014 | Ovens
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
The fan works but oven does not heat up
If the fan is working o/k, and it it is an electric oven, then the oven element has probably failed.
It is usually located at the rear of the oven compartment behind a removeable cover.
Hopew this helps you.
Dec 09, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
Bottom Element Open Circuit & Fan Element not working
No resistance in a bake element is a bad element. Replace it.
Most fan come on with a rise in heat. No heat/no fan.
Apr 08, 2009 | DeLonghi Ovens
Jun 10, 2008 | Ovens
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Ovens Logo
59 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Naftali Haskell
Level 1 Expert
Jason Harris
Jason Harris
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
