Question about Nikon Coolpix 2000 Digital Camera
Lens defect: stays out of the camerabody
Since 2004 I make digital pictures without any problems with a Nikon Coolpix 2000 camera. Now for the first time a problem: the lens-system won't turn back into the camera. Error message in screen.
Battery power is ok.
I openened the camera (many very tiny screws). Can't find a problem at first look.
Not possible to set motion in lens-system.
Is it possible the motor/driver is defect?
Would like to fix it, don't like the idea of "having to say goodby" to this camera.
Who can help me with tips of instructions how to fix this problem?
Finaly my husband managed to repair the lens.
By opening the lens, 4 screws at the bottom of the lens.
Inside the lens at first side everything looked fine.
By second look (my excuses for this bad English.....) a cog-wheel at the outer circle of the lens-system had shifted a few mm to the right. By that blocking the cog-wheel system. This was once noticed, easy to repair.
The camera must have been fallen the other day, otherwise I can't explain this mechanical failure.
We also foud a very small metal spring in the lens, loose. And we coudn't find the place where it should have been, where it must have been functioning?
At this moment the camera seems to work, but maybe not for a long time.
So after this 'excersise' I decided it's time for a new digital camera. The prices are better now than in 2004. For less money (despite inflation......) you buy a much better camera now.
greatings from the Netherlands
Soena
Posted on Mar 30, 2008
SOURCE:
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
The lens does not stay open long enough to pose picture. It closes.
These camera's will do that when the battery is very low sometimes.
I'm not sure that is your problem due to lack of more details, but it is a possibility.
Mar 08, 2015 | Nikon Coolpix S3300
Nikon coolpix s70 has blurry pictures even after resetting to default settings. Camera has not been damaged or dropped.
Hi you have lens unit defective. Even if you didn't damaged and dropped, its appearance problem is the lens unit, you can bring to your local repair shop. It is quite easy problem. some point they could save part, but time is money. they would want to change the part. your part from nikon usa is very expensive, but from ebay it is very cheap. It is used but it would be reliable in most case. http://cgi.ebay.com/Camera-LENS-ZOOM-UNIT-Nikon-Coolpix-S70-BLACK-/180672085419?pt=Digital_Camera_Accessories&hash=item2a10e53dab#ht_500wt_1156 If you buy and bring it with camera to your local repair shop, they would charge less labor then you bring camera only. repair shop would consider that you know what it is going on. Thanks and kindly! ( labor they would charge around $25 to 75 depend on what they want to charge)
Jun 02, 2011 | Nikon COOLPIX S70 Digital Camera
While shutting down after downloading pictures, I
Try going to this page at the Nikon site, and work from there. You might find your answer if you start here:
http://www.nikon.com/about/news/2004/0128_03.htm
Good luck,
-a.
Apr 01, 2010 | Nikon Coolpix 3200 Digital Camera
Nikon coolpix 2200 zoom problem
I was having a "Lens Error" with my Nikon Coolpix S210 camera and this websites' tips fixed my camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 16, 2009 | Nikon Coolpix 2200 Digital Camera
My coolpix camera reads lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 25, 2009 | Nikon Coolpix 2000 Digital Camera
Lens error appaers and cannot take picture
i just fixed the problem. if your error is like mine, than when the lens goes out, hold it so it stays in place. and blow directly on the lense glass thing. than restart the camera and it should work. ok good luck =]
May 19, 2009 | Nikon Coolpix L14 Digital Camera
Nikon coolpix p1 camera takes weird outdoor pics
If the playback of old pictures are fine but camera mode displays lines across, you may have a defective CCD chip. These are expensive repair averaging around $110. Some local shop may able to repair it. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 26, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 21, 2008 | Nikon Coolpix P2 Digital Camera
Nikon 5700 takes a blank picture
There was a line of defective Sony sensors that went into a lot of cameras between 2004 and 2005. As far as I know the 5700 was the primary victim in the Nikon line but Nikon is offering to repair or replace the affected cameras regardless of warranty status. http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html Good luck
Apr 29, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 2000 Digital Camera Logo
94 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
