Question about Hoover Elite U5061-900 Bagged Upright Vacuum
Describe your hoover elite ii manual 560Problem HOW DO I OPEN AND PUT IN NEW BELT
5 Suggested Answers
  • 9 Answers
SOURCE: How to open the hoover DM4526 to change the belt
there are normaly5screws 3in the front 2in the back remove these and the bottom should come off pull the brudh off repace belt on to brush put brush back in to seating pull brush on to drive and re,asemble
Posted on Dec 06, 2007
Kazong
  • 152 Answers
SOURCE: How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Posted on Jan 17, 2008
Vac Belts
  • 701 Answers
SOURCE: hoover elite how do i put the belt on
Here is the belt you need: Hoover U5061900 Belt
Simply turn the machine over and you will see (4) screws, remove them and you will be able to access of the belt.
Posted on Dec 14, 2009
  • 127 Answers
SOURCE: Replace broken belt
usually the beater bar pops out
Posted on Jan 08, 2010
My hoover elite belt comes off within 5 seconds of turning it on
Those machines sit in the box in transit across the world and waiting for purchase. In time the rubber stretches out from just sitting there. In the old days they packed the belt separate from the vacuum and you had to put in on yourself. Today's buyers aren't so handy so the manufacturers are forced to put the belts on before sale. 80% of returned vacuums are due to this! Find the local Hoover Warranty center on the hoover dealer locator at hoover.com and they'll set you up with a new belt at no charge. Good Luck!
Oct 03, 2012 | Hoover Elite Rewind Bagless Upright...
I need a replacement belt for Hoover Elite upright vaccum ,model no. U5043-930. What belt do I get?
Your vacuum cleaner originally came with Hoover belt part number 38528027, however Hoover has now discontinued this part number, and replaced this belt with the new belt which is part number 38528040.
The new belt is a little bit smaller then your old one, but unfortunately this is the only belt that Hoover currently makes that will fit your model.
Here's a direct link to our website if you still need to purchase one:
http://www.govacuum.com/agbelhoovpar7.html
I have also uploaded the parts diagram and instruction manual for you. The parts diagram gives you every single part number for all parts on your vacuum should ever need to know another part number. The owners manual will give you step by step instructions on how to change the belt, as well as other maintenance instructions.
Part Diagram for Hoover U5227-930:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/Part-diagram-hoover-u5043-930.pdf
Owners manual is actually for the commercial version of your vacuum, but this will be identical to your instruction manual which Hoover doesn't have available for free:
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you. If it was, please be so kind and rate my repair helpful by clicking the thumbs up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U5227-930 Elite Upright Vacuum
Hoover elite how do i put the belt on
Dec 14, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hoover elite, model no. u4671-930
in the front on the bottom you will see 2 slots put a small screwdriver in and push up on the clips in the slots and the bottom cover will come off .be careful not to break the clips.just push up on the clip and pull out on the cover at the same time.before you replace the belt clean the old rubber off the motor shaft first ,if you don't the new belt won't last very long
Apr 29, 2009 | Hoover Elite U5061-900 Bagged Upright...
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Changing the belt
I'm not familiar with that model, as it is fairly new to the market, but the previous models had a plastic plate that covered the roller. There are two clips that must be depressed as you gently pull the plate away from the machine. This will allow the removal of the plate so that the roller can be removed and a new belt installed. This is a new model, so you must have the manual still. You can also check www.hoover.com for more instructions and last time I checked, they had a manual download feature available.
Oct 24, 2007 | Hoover Elite Rewind Bagless Upright...
Hoover Elite U5061-900 Bagged Upright Vacuum Logo
377 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
