Question about GE Washing Machines
My Adora front load washer is shredding my clothes. It doesn't happen every load but some of my shirts are getting ripped/torn. There doesn't appear to be anything sharp in the tub. Anyone know what is causing this problem and how to correct it?
  • 3 Answers
Had that problem for a while with mine, It seemed to do it once in a while....then we stopped putting our jeans/pants in with the rest of the colors. and it stopped happening. we was our pants seperatly with them zipped and buttoned now, have not had anymore ripped or torn clothes since.
Hope it helps.
Posted on Oct 30, 2010
Clothes getting burnt & torn in maytag front loading washer...how to resolve this issue asap?
Check the inside of the drum. Chances are, there is a sharp object pointing out that is doing this.
Jan 13, 2014 | Maytag EPIC MFW9700S Front Load Washer
I had 2 under armour golf shirts torn by this washer
ok.Sounds like could be rip in inner drum or rough edge.Check this 1st also the inner paddles are okay...
Jun 24, 2010 | GE WCVH6260F Front Load Washer
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Adora Frontload Washer shredding clothes
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Mar 29, 2009 | GE WSXH208A Front Load Washer
Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Dec 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
GE Front load washer clothes coming out with holes/torn/even shredded
Metal inside washer drum may be faulty and causing tearing of clothes (run your finger around the inside when empty and you will feel where it snags). Had same problem, only got worse and ruined many expensive t-shirts! Replacement of drum is required and is extremely costly if not under warranty!
Jun 05, 2008 | GE WSXH208A Front Load Washer
Clothes got tangled with rubber seal inside and ripped it. How do I fix/get a new seal?
This part is a problem on many front-loaders and never really goes away. The rubber seal is a replaceable part and should be supplied under warranty. There is no way to fix it.You should try very hard to get Sears to pick up the labor cost as well.
Mar 14, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire Front Loader Ripping Clothes
Frigidaire washer sucks. I'm tired of this useless machine ripping my clothes. You need to change your bellows(boot) kits around the door on front load. I have changed this kit twice now and each time, I spent $200 in repair fees. I wished I never bought this washer. Will never recommend to anyone i know.
Dec 20, 2007 | Frigidaire ATF6000ES Front Load Washer
Torn clothes
I've had this probelm as well and I suspect it to be the gasket that goes around the opening of the washer in your case(s). Mine is torn nearly halfway around and I believe the clothes are getting caught there. I called in for service two weeks ago but they keep telling me that the part is on backorder. Not a great problem to have with two toddlers!
Nov 04, 2007 | GE WSXH208A Front Load Washer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
186 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
