Question about Amana NDE2330AY Electric Dryer
Dryer squeaks for a few minutues when you first turn in on and then everything is fine
    President:
  • 1,430 Answers
It could be one or more of the items listed below.
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
Posted on May 13, 2010
My ge dryer dvlr223eeoww is making a loud noise when you turn it on it will work fine for a few minutes if a lot of clothes are in it then after a few minutes it sounds like it is going to fall apart.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 04, 2011 | Dryers
At the start of the drying cycle the dryer would squeak for a few minutes as it heated up the squeaking would stop ;now the dryer will not turn on, only hums whn the start button is pushed..HELP!!
heatman101
Jul 30, 2011 | Dryers
I have a gas dryer Maytag Dependable Care Model 6 cycle about 11 yrs old...Has a steady squeak as it runs , seems to be getting louder . Everything on the dryer seems to work fine other than this...
heatman101
Jul 14, 2011 | Dryers
When the dryer starts it makes a quick grinding noise like it is having trouble starting. After only 1 second that noise goes away and the dryer appears to be working fine. It will stay running anywhere...
heatman101
Asker
Mar 09, 2011 | Whirlpool LER4634J Electric Dryer
The dryer works, after a few minutes of running a noise is generated from the motor section. Looked a pulley, drum and belt, everything seems to be operating fine. It almost sounds like the motor is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 01, 2010 | Frigidaire GLEQ332A Electric Dryer
The dryer works, heats, tumbles, everything is fine. Except that there is a thump as the drum turns that seems to be coming from the top.
heatman101
Jun 17, 2010 | Kenmore 93042 Gas Dryer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Squeaking Sound like the fan belt needs replacing.
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 05, 2010 | Hotpoint TDL14 Electric Dryer
Intermittent Squeaking
You know how when the pads on your car get worn they start that noise? Well the bearing that holds the tub has a metal bracket. When that plastic wears down it begins to makes those noises. If left alone the metal bracket will eventually cuut into that drum bearing like a guillotine. I have pictures. Have the women and small babys leave the room: Click (HERE)
Jul 08, 2009 | Frigidaire GLER341A Electric Dryer
Amana NDE2330AY Electric Dryer Logo
130 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
