Question about Sanyo Audio Players & Recorders
Sanyo RM 5700 clockradio on backup loses time
Hi - my clockradio keeps time fine when the power is on, but loses time rapidly when on backup. The battery is new, replaced several times to confirm. Please help!
sandrew
  • 2961 Answers
SOURCE: Laptop Clock loses time
This is a sure sign that your CMOS battery needs replacing, but you may need to take to a qualified repairer as the battery can be hard to access or even locate.
Posted on Dec 16, 2006
informatica
  • 1114 Answers
SOURCE: BIOS/RTC/CMOS backup battery
Please tell us the type / part number of the battery and where you are located. It's a big world out there!
Posted on Aug 20, 2007
SOURCE: flashing red power light
The problem here is condensation inside the camera. I leave the camera turned off, remove the cassette tape and then point a hair drier on warm or low heat and slow speed right into the innards of the camera through the open cassette tape door. I run the hair dryer for 5 minutes and then replace the cassette. If the camera still dosen't work just wait for another 5 or 10 minutes and then it will work OK.
Posted on Oct 13, 2008
  • 203 Answers
SOURCE: my ebel watch loses time
get them to have it checked in their repair shop and tell them its not the battery
Posted on Dec 07, 2008
Tyranny
  • 21 Answers
SOURCE: the phone is not recognizing the backup battery. can someone please help me on how to charge or replace the backup. battery
The backup battery is located inside the phone and canno be replaced by normal methods. the phone needs be disassembled and the battery are solded on the board.
the lifetime of these bateries are very high, maybe 5 or more years, and the charge occurs every time when you charge the phone.
Try to leave your phone charging for more than 3 hours, and if the battery dont charge, try a master reset on it.
If ater all, the battery dont charge, maybe you make some mistake or shorted some circuit. Take apart your phone again and re-check all the steps to reassembly.
Good luck
Posted on May 24, 2009
How to unlock my security code for nokia xpress music 5700
Hi Nicholus, If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. BUT if you've forgotten your pattern code The link below is a youtube video of a guy shows 3 way but the 3rd way is a factory reset meaning you loose every thing in your phone
but the first two ways are worth watching. I hope this helps...... CHEERS..
EASY WAYS How To Unlock Android Passwords
Apr 16, 2016 | Nokia 5700 Cellular Phone
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
Relay clicking
Possibly a gradually failing power supply
Dec 31, 2013 | Sanyo Televison & Video
What could cause a 27" Sanyo flat panel dp26648 to lose picture, but keep sound?
There are two reasons why your Sanyo DP26648 would has sound but no image and both are equally likely in our experience.
First, you may have a problem in the section of the power board that supplies the backlight module (called inverter) with 24V.
We've seen that several times and the problem is usually minimal - only electrolytic capacitors gone bad - and other times not so minimal.
We have a repair service for that power board and we may have some boards available too...check out at
http://www.coppelltvrepair.com/search?Q=DP26648+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Apr 04, 2012 | Sanyo DP26648 LCD TV
I Need an instruction manual for a clockradio...model no1CF-C318.Thank you
That's a Sony model ICF-C318, I believe. You can get the manual here.
Feb 25, 2011 | Sanyo RMXCD400 Clock Radio
When i shut my bc60xlt off i lose all saved freqs , i have put them back in several times,but i keep losing them.
Your scanner has a capacitor-based backup circuit, and the capacitor has likely died of old age. Youtr only solution is to keep the unit powered up.
Jul 19, 2009 | Uniden BC60XLT Handheld Scanner
Backup battery
The backup battery exists to protect your data when the main battery dies. It only has enough power to keep the internal memory 'alive' so you dont lose your files, settings etc.
When the backup battery dies it should be replaced as soon as possible, as the main battery will power the internal memory only while it has charge. Should the main battery die it would be like performing a hard reset.
Jun 16, 2008 | HP iPAQ hw6515 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
65 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
