This is me again, with the Neptune washer. So, I opened up the back and looked around...I found the belt laying on the bottom of the washer... Am I able to put this on myself, or will I need a repairman to do it. Obviously, I have not done this before. I have a Superstack SL-3 model number MLE2000AYW Thanks.
  • Bridget Burkot May 14, 2010
    Yes, very helpful. Upon putting the belt back on, it continues to slip. DO I need a new belt or is there another possible problem?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. There are two belts in your washer one is the Drive belt and other is the one on the tumbler. If you have some expertise then you can do it yourself as you have to start with removing the front panel, rear access panel and the front weight. After this is done then from the rear, locate the belt adjustment wheel and note the adjustment number aligned with the rib of the outer tub. This will help later when the belt adjustment wheel is placed back onto the outer tub and the belt is remounted on the motor and drive pulley. Remove the bolt securing the belt adjustment wheel. If you get all this done by a repairman he’ll charge you around $150 including labor as the belt is around $30. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 13, 2010
  • Rylee Smith
    Rylee Smith May 14, 2010
    You'll need to replace the belt.
    Thanks
    Rylee
Neptune washer will not extrACT water
Not belt or pulley!
Pump located below drum blocked or filter blocked
May 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
I just ordered the replacement v-belt for my electric maytag neptune dryer. I just need to know where the belt is suppose to lay along the drum. There is an indentation along the bottom or does it lay...
Generally you can see where it has road previously. However once you get the belt on and through the tensioner, you can turn the drier by hand and it will adjust to the right spot. It will give little resistance, but turn it both ways to be sure. Good luck!
Feb 07, 2011 | Dryers
How do I open it to get access to change the belt?
All maytags i have encountered open from the front. There should be two screws at the bottom of the front or under opening of door. The top pops off and opens up to lay back. Swing front over to side of machine being carfull of door switch wiring.Look through botttom of dryer and you will see motor and idler pulley setup. belt is routed around drum, under pulley and around motor shaft. Hope this helps.
Dec 25, 2010 | Maytag PYE2300AY Electric Dryer
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
Pulley Came off!!!
pull the belt enough to spin pulley.use extension for you tools
May 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Feb 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Drum doesn't turn in maytag neptune MDE9700AYW
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Jan 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
