Servis m9090 washer dryer, drum will not rotate power from timer to motr. Does anyone have circuit diagramme for this machine...
  • 1003 Answers
SOURCE: washer dryer - dryer does not heat up
REPLACE HEAT ELEMENT TO SOLVE DRYER PROBLEM
Posted on Feb 02, 2008
  • 1462 Answers
SOURCE: changing door gasket on Servis M9813s washer dryer
you can clean in situ just as good as if you remove it
Posted on Jul 12, 2008
  • 7 Answers
SOURCE: model LEQ2152ES0
check the drive belt is on the pulleys
Posted on Jul 20, 2008
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
agitateme
  • 88 Answers
SOURCE: My dryer wont come on no drum rotation or any
First of all, it would be a 30 amp 2-pole breaker, and if checking with a normal meter, you should read 240V, (220 is a nominal voltage, not what will actually be present). If you heard crackling in the panel, I would call an electrician right away! It's possible you did lose one or both phases from the supply. Once that problem is squared away, please re-post the outcome, and we can go from there.
Posted on Nov 11, 2009
GE Profile dryer keeps running and timer switch doesn't move
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Aug 13, 2014 | Dryers
I have a Servis M9409S washer dryer. The dryer isn't heating up at all, and I'm assuming it's the heating element. Does anyone know how to replace it?
There is only one place that I can find that part: http://www.partmaster.co.uk/servis/m9409/element/catalogue.pl?path=66991,61187:66997&model_ref=29129&refine=element
Jun 05, 2014 | Dryers
Won't turn on
Hello 33bakerfamil - You may try and reset the washer by disconnecting the power to the unit for up to ten minutes by flipping the circuit breaker off and back on. Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Will the drum manually rotate (when it is not in use)? If it does not, then the drum could possibly be unbalance and/or have a broken shock/bearing. Other possibilities are: experiencing an issue with the door lock assembly, control board communication, faulty timer/pump, and damaged cord. Because it could be a number of any one of several underlying causes, I would recommend reaching out to an expert to properly diagnose and repair the unit.
Apr 18, 2013 | Frigidaire GLGR331A Gas Dryer
Hoover washing machine - door won't open and drum won't spin, error displayed is e08, ideas anyone? Thanks :-)
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Mar 13, 2010 | Washing Machines
The timer runs but dryer does not heat or drum will not turn .
hi friend,
Is your washer getting power? The first things to check if your washer suddenly stops working are your circuit breaker, lid switch, or fuse box. After making sure there is power to the appliance, you can start troubleshooting other problems. To verify there is power at the outlet, try plugging in a small electric appliance such as a hair dryer or radio.
Sometimes the motor will overheat and then requires a cool down period before it will restart.
Is the machine in a pause cycle? Is the lid up? Washers will not spin or agitate if the lid is up. There is a lid switch probe that can sometimes become dislodged. This is generally a little plastic piece that is in the hole under the lid on the washer. This probe activates the lid switch when the lid is put down. Manually advance the timer if the pause is too long.
There are some washer models out there that will not run at all until the water is filled to the level that has been selected. Sometimes the mechanical timer knob on certain washers doesn’t exactly line up with the graphics on the control panel. You can try advancing the timer slightly and pull the knob out again to see if it will start.
hope this helps u
thank u for using fixya
please rate me.......................
regards
sivaranjini
Sep 14, 2009 | Kenmore 62602 Electric Dryer
Creda Easy Load Dryer
Sounds like the timer is the problem, the reversing contacts have probably failed
Nov 09, 2008 | Creda IWD12 Front Load Washer / Dryer
Washer will not start
First check youp plug point by plugging in a lamp or something, there could be no supply; next check your washer's plug.
Jan 17, 2008 | Whirlpool LSR6232J Top Load Washer
No washing
there may be some loose connection between the board and the rotating drum.....try to fix it properly
Jan 02, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer Drum not rotating
If warm air is still coming from the unit, but the drum is not rotating, it sounds like your drive motor is fine, but your drive belt is broken. Depending on you dryer model, these can be fairly easy to check, or may take a little creativity to get the dryer apart. Knowing your dryer model number would go a long way towards assisting further.
May 06, 2007 | Whirlpool LSW9750 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
