Question about Brother MFC 7420 All-In-One Laser Printer
My mfc 7420 is adding an image from a previous fax to all of my outgoing faxes. when i shut the machine off it clears it for one or two faxes and then it comes back. help?
  • 1,606 Answers
Somehow you have a page of data stuck in the memory. It should be cleared each time you print. This might indicate a bigger problem starting so if this repeats you may beed to take it into brother.
To get rid of this we need to do a reset. You need to keep pressing the DOWN or UP keys a couple of times till you see ‘Maintenance 99’ displayed on the display. Then hold down the ‘Set’ button to go to standby mode. Please note that if you press the exit key only after typing in a single digit then the machine goes to maintenance mode in initial stages. Just as a word of warning this can reset the printer to factory default which means any settings or stored numbers (fax numbers etc) will be lost.
That should get rid of your ghost in the machine.
Posted on May 13, 2010
Clearing fax numbers from my brother mfc 8220 printer
press menu*2864, display will flash, then enter 01 on the keypad,wait 30 seconds and then press 99 on keypad, machine is now returned to factory settings
Nov 20, 2011 | Brother MFC-8220 Fax
Fax automaticaly daling #365 etc like tha number how can reset my MFC 7450 printer
Found this here...
(For MFC-7420)
When you turn off the MFC's power switch its memory will be cleared. To check
whether the MFC has faxes in its memory see Checking if the MFC has faxes in
its memory on page 11-5. If there are faxes you need to save them before following
the suggestions below (See Transferring faxes to your PC on page 11-5 or
Forwarding faxes to another fax machine on page 11-5).
Turn off the MFC's power switch and then turn it on again. If the error message
continues, leave the MFC for several minutes and try it again.
Check the settings in your application software to make sure it is set up to work
with your MFC.
(For MFC-7820N)
continues leave the MFC for several minutes and then try it again. (The MFC can
be turned off for up to 4 days without losing faxes stored in the memory.)
Looking through this manual, this is the only solution that I could find. There are options on the 7820N model in the menus that will allow you to reset the printer itself, and i quick search through the above link for "printer reset" should bring you to the menu selections for that.
Jun 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Transmittal print with image
it's not an error, just don't have this function for this machine.
May 20, 2009 | Brother MFC 7420 All-In-One Laser Printer
Won't fax
You have to get your answering machine and your fax to play nice. Read the instructions for both. I think I have my answering machine to pickup at three rings, and the fax to pick up at five. Don't have the fax answer first. Don't have both machines answering at the same number of rings.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
How to print fax confirmation sheet - MFC-7420
first print out the help sheet, might be in reports then u have all the information at hand
Nov 21, 2008 | Brother MFC 7420 All-In-One Laser Printer
Vertical lines on photocopies/faxes
The MFC-7420 Manual recommends cleaning the scanner glass and white plastic bar above it with isopropyl alcohol. Page 11-22 has a diagram.
I am having a similar problem but cleaning it did not work. But try that first.
Oct 15, 2008 | Brother MFC 7420 All-In-One Laser Printer
Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
Dec 05, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
