Question about Pioneer Audio Players & Recorders
I disconnected the negative battery cable, and reconnectd it to fix check engine light, now my aux 2 wont show up on my radio dial, so my sattelite radio wont work
  • 666 Answers
When you disconnected the power from the radio you lost your presets radios have two power lines one is primary and is used to power everything while on the other is a remote power line and is only used to keep clock and presets so what you going to have to do is ind your user manual and reconfigure the radio to accept the satellite radio on the second aux input
hope this helped
Robb
Posted on May 13, 2010
  • steveoly May 13, 2010
    I cant find the manual
How do I reset the check engine light after I fixed it?
If you have a Code scanner you can do it there.. if not, Unplug the Battery Positive and Negative terminals for 5 minutes then Reconnect.. it will reset and check everything..
Oct 17, 2014 | Chevrolet 2005 Chevrolet Silverado 1500...
Aveo battery and brake light came on
sound like alternator faulty or drive belt could be slipping due to broke drive belt tensioner,check make sure alternator wires not damaged or disconnected. with the engine idling check alternator voltage out put at battery with digital volt meter, should be 13.5 - 14.5 volts.if not alternator faulty.also check alternator fuse before replacing alternator.turn off radio first before disconnecting negative battery cable,to remove alternator have the auto parts store check it out alternator before buying a new one.reason i say turn off radio first if you dont you will lock it out when you disconnect the negative battery cable.
Feb 07, 2012 | 2007 Chevrolet Aveo Sedan
Dash lights flicker when ya turn key and wont start"" (then after you keep turning key serveral times lights quit flashing and car starts" what do you think it could be??
have battery checked, sound like battery weak or battery cables loose or battery post and cables need cleaning has a lot of corrossion.make sure you turn off radio before disconnecting negative battery cable if you decide clean battery cables and battery post,reason for turning off radio to keep from locking out radio play code.have battery tested battery volts should be 12.6 volts.
Feb 01, 2012 | 2002 Oldsmobile Intrigue
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
My 2000 oldsmobile intrigue is not starting no power to stater is a 3.5
CHECK BATTERY VOLTAGE IT SHOULD BE 12.5 VOLTS.IF NOT BATTERY WEAK NEED CHARGING OR REPLACED.IF BATTERY GOOD.TURN IGNITION SWITCH TO ON POSITION WITH ENGINE OFF.DASH LIGHTS SHOULD LIGHT UP IF NOT.CHECK IGNITION SWITCH FUSE.IF FUSE GOOD YOU HAVE A BAD IGNITION SWITCH.IF SWITCH IS GOOD.I AM LOOKING IN FAULT IN STARTER SOLENOID OR STARTER.OR BATTERY CABLES NEED REPLACING.WARNING TURN OFF RADIO BEFORE DISCONNECTING NEGATIVE BATTERY CABLE SO YOU WONT LOSE RADIO PLAYING CODE.
Mar 31, 2010 | 2000 Oldsmobile Intrigue
2000 isuzu rodeo engine light wont turn off. engine runs smoothly, no problems. mechanic cant get codes from processor
try disconnecting negative battery cable for 5 minutes or so.this allows computer to re-set.you'll have to re-set clock and radio presets.
Sep 22, 2009 | 2000 Isuzu Rodeo
Possibly starter?
Q45 4.1 ENGINE STARTER IS NEXT TO STEERING GEAR.
Jul 26, 2009 | 1997 Infiniti.5 Q45
What could be dragging my battery down after 2 days of not starting it?
Lots of stuff. An after market alarm,malfuntioning radio,bad battery,bad door pin switch for the interior lights. Best thing to do is charge the battery if it's in fact good, thenunhook the negative battery cable & connect a test light from the disconnected cable to the negative battery post. If it's a nice bright light it's got a draw. If it's really dim,that's the memory for the computer,anti-theft,radio memory. I mean dim,like barely lit! That's ok. If you don't have a test light disconnect the negative cable & touch it to the negative battery post a few times & if there's a big spark,there's a draw. If there's a draw & there's nothing on in the car,like an interior light,etc, than start with the inside the car fuse box & while holding the open door pin switch test each fuse for power. If anything has power that shouldn't with the key off that's where to start. Do the same for the under the hood box as well but disconnect the hood light. If you are using the Viper alarm system,junk the system. That alarm causes your problem & in alot of cases a fire.
Jul 22, 2009 | 1995 Chevrolet Camaro
How do i install starter on 1994 sls
4.9 engines disconnect negative battery cable. besure radio turn off so you wont lose code.raise vechicle support on jack stand.remove starter cover .now models you had to remove exhaust cross over pipe then remove starter.the 4.6 engines you remove negative battery cable then the intake manifold.then remove starter.
May 13, 2009 | 1994 Cadillac Seville
RESETTING CHECK ENGINE LIGHT
I can only assume you have had the code extracted and fixed the problem and looking to do a reset only. If you have not fixed the problem the reset wont do any good. That being said, in most all chrysler vehicles, the check engine light can be reset by disconnecting the negative battery cable for at least 15 seconds. However on OBD II (usually 97 and newer) models the light can only be reset with the use of a scan tool. CAUTION : If the stereo in your vehicle is equipped with an anti-theft system, make sure you have the correct activation code before disconnecting the battery cable.
Sep 26, 2008 | 2006 Chrysler 300
175 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
