Question about Beko Dishwashers
My Beko dsfn 1530 dishwasher door doesn't close flush. Can't see any obstruction. Have only had it two weeks appreciate it is a cheap model but did expect this. Any ideas...thanks
aborcass
  • 2651 Answers
SOURCE: Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Posted on Mar 24, 2008
  • 236 Answers
SOURCE: Dishwasher won't start
may be in flood mode. tip the unit sideways and see if water leaks from the base if so continue to tip it until it all drains out, then start it on a wash if it starts you have a component leak that will have to be sourced.
Posted on Mar 14, 2009
SOURCE: Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Posted on Aug 24, 2009
Testimonial: "Hey, thanks for the advice. Worked like a charm. Hopefully Frigidaire has improved their design."
  • 784 Answers
SOURCE: I have a 2 week old Beko dishwasher and last night
Either there is a leak activating the error alert or there is some blockage from the drain hose to the food dispenser.
Unplug the power cord for 24 hour to reset the disrupted logic back to the original stage to see it it help. If the manual shows the diagnostic mode, try to set to manually drain so a new cycle can be started to test.
Posted on May 08, 2010
  • 472 Answers
SOURCE: Dishwasher will not run. key
could be a few things the touch pad display has a ribbon cable that connects to the pcb or control assemble...the touch pad could be bad /// the pcb(main control) has a fuse in it and they often go bad this reuires taken the cosole apart and removing the screws on the inner door to get it off. if the fuse is not bad you have either a bad pcb or touch pad... before doing all this kill power to unit at breaker for at least thirty seconds and then reset...hope this helps
Posted on Jan 02, 2011
We are trying to replace a door handle on a beko dishwasher DSFN 1530B. We cannot remove the programme panel all screws have been removed and we are stuck. Can you advise
before you can remove the top panel you have to remove the front outer door panel, there are screws down the sides to remove it.
May 14, 2017 | Beko Dishwashers
The start/pause button on my Beko dishwasher DSFN 6831 W is stuck in on position. Lights are on but machine does not start.
I think you have a control board fault, this is the part that is connected to and part of the buttons.
Mar 23, 2017 | Beko Washing Machines
Beko de2542f dishwasher
If you live in Rancho Cordova, CA and need dishwasher repair service call us at 916 823 3070 or visit our website Dishwasher Repair Rancho Cordova 916 823 3070 GE Maytag Ken
Sep 03, 2017 | Beko Dishwashers
The DSFN 1530 AAA Class dishwasher won't start. the lights are on. there is water in the machine.
Could be the door interlock switches. There are usually two of these. I removed them on my GE and replaced them with an illuminated push button kill switch.http://www.auberins.com/index.php?main_page=product_info&products_id=360
When switch is on the control panel is powered up as well as the rest of the unit. If you need to add a dish after activation you just push the button before opening the door and it interrupt the cycle which resumes with another push.
Sep 04, 2014 | Dishwashers
Beko dsfn 1532 start button will not stay down
We have the same problem. How did you resolve this issue?
Dec 30, 2012 | Beko Dishwashers
No power to beko 1530 dishwasher
first make sure that power is coming in by checking connection with multimeter.If there is power coming to where it is wired up then the problem maybe the handle swtich either burned out or not making connection when the door is closed
Jan 29, 2012 | Beko Dishwashers
My Beko dishwasher DWD 5410 will not drain the water and I can not hear the pump running.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 19, 2011 | Dishwashers
My tablet will not dissolve ?
The usual cause for dishwasher tablets failing to fully dissolve is a failed dishwasher heating element.
Sep 21, 2010 | Beko Dishwashers
Dishwashers Logo
271 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
paulcarew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
