Question about Acer Aspire m5640 PC Desktop
Monitor has power, computer will not power up after blown circuit
    President:
  • 548 Answers
Try to make a "clear CMOS". There should be a 3 pin slot on the motherboard. Remove the jumper from the first 2 pins and put it to the other 2. The middle pin will be always occupied.
If not, try to change the power source and see if it does the same thing. If so, then you have to change the motherboard.
If you need further assistance, just leave a comment.
Posted on May 13, 2010
THE MONITORES POWER LIGHT KEEPS BLINKING AND THE MONITOR WON'T WORK AND STAYS BLACK
It has shorted out transistors in the inverter circuits, also look for cold solder joints, fuse.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement board:
http://www.lcdrepair.us
Aug 09, 2010 | Dell E173FP 17" LCD Monitor
Monitor is on but will not display anything
Check to see if the back light inverter circuits has blown fuse and if it is getting the 12~18vdc from the power supply section.
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 02, 2010 | Hyundai Electronics W240D LCD Monitor
Monitor cycles like circuit breaker cycling.
Check the caps in the power supply with leaking/bulging top.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 01, 2010 | Princeton Digital VL1916 19" LCD Monitor
Why is it that my monitor keep on and off while still in used?
You may have failing power supply or backlight inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 25, 2010 | AOC LM 520A 15" LCD Monitor
Monitor has no power to it. The power cable and V...
May 20, 2010 | Princeton Digital LCD1711 17" LCD Monitor
No picture
Look for bad caps (leaking/bulging top), blown fuse and shorted transistors in the inverter and power supply circuits
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Westinghouse L2046NV Monitor
Monitor just went off. no power light. changed fuse but monitor is completely dead
possibly a power surge killed the main board in the LCD. if the fuse was blown i would suspect a power surge. you could replace the circuit board. either that died or the power supply died- depending on if it has internal or external power supply that might be blown as well.
i would take it to a professional LCD/ LAPTOP repair person. they should be-able to test it and let you know what needs to be replaced
Aug 06, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Plug it in with no input connected,press the
I suggest you don't.
There are no user friendly replaceable parts in there.
There May be an inline fuse in the AC circuit, but it's probably a circuit breaker. (Closest thing to a user friendly part, that you'll find)
I suggest you take it to a 'Mom & Pop' computer shop, and see if they will check for a blown fuse inside. The small qualified shops like these, have real computer techs, and not 'Geeks are Us'.
Plus they're cheaper.
If it isn't something simple like a blown fuse, or bad circuit breaker, it's probably the power board.
(Usually the front cover comes off, from loosening it on the backside)
The reasoning for dissuading you from opening the monitor, is that there are Electrolytic Capacitors inside.
They are designed to hold a charge for weeks, sometimes months.
Should you touch the terminals making a circuit, or touch the circuit they're in, and complete a circuit, they could release their charge to you!
This can easily result in a bad shock, or 'Put X's in your eyes'.
(The Electrocution warning on the outside is For Real!)
Apr 22, 2009 | Acer AL2223W 22" LCD Monitor
VX924 Blown Fuse
What are the symptoms? How do you know the fuse was blown on the monitor you bought? The fuse on vx924 is soldered onto the circuit board. If you have any symptoms that require power its probably not the fuse. The back lighting on this unit has a problem. Three 25v 470uf caps on the circuit board are underrated and have a tendency to go bad. Replace them with 35v 470uf caps.
Sep 28, 2008 | ViewSonic VX924 19" LCD Monitor
E17T Monitor
monitor problem any short circuit may be in secondrry side of monitor
Mar 15, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Acer Aspire m5640  PC Desktop Logo
216 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
