Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Lamp Hour Meter
My TV was purchased in 2003. I have replaced the lamp once since that time. When that lamp went out, there was no warning or notice. The TV simply did not turn on. The service tech told me where to purchase a lamp, and how to replace it.
Now, I'm getting a warning message that the lamp should be replaced, and the lamp hour meter should be reset. Thinking that since the first bulb did not run its complete life cycle, the lamp meter wasn't reset when the tech was here. And, not having a warning message (as it does now), I didn't know to ask how to reset the meter. The warning message "The lamp needs to be replaced, and the lamp hour meter needs to be reset".
How do you reset the lamp hour meter
  • 2 more comments
  • the_miker May 06, 2008
    I am experiencing the same issue where the bulb meter is expired but
    the bulb has been replaced recently. Unfortunately, the remote doesn't
    work and I tried doing the meter reset with my Universal remote with no
    luck. Any suggestions?
    Thanks!
  • cesar Jul 28, 2008
    tv says lamp timer needs to be reset
  • Anonymous Nov 14, 2008
    i need to reset the lamp hour meter. how do i do this?
  • rico r
    rico r Nov 27, 2013
    ok i have a 61 inch RCA hdtv dlp hd61lpw62....how do you reset the lamp timer
  • Panasonic Master
  • 8,617 Answers
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Apr 01, 2008
  • Lee Ramirez
    Lee Ramirez Mar 14, 2014
    Thank you so much my hour meter was reset
  • 47 Answers
If you have a PT50LC13, the procedure is to press and hold both the VOL- button on the set and the PIP button (the one at the bottom left) on the remote for 5 - 10 seconds. You will see a message "LAMP TIME WAS RESET TO 0".
#1 - make sure the remote is the one that shipped with the television
#2 - make sure you're aiming the remote at the IR sensor on the television while you perform this procedure
#3 - make sure the message is not on the screen at the time - it will not work if you see the lamp timer needs to be reset message
#4 - make sure the remote, being a universal, is in TV mode.
Posted on May 07, 2008
I have a PT-43LC14 and the procedure was to press and hold the SPLIT/PLAY button on remote and VOL on the set for 5-10 sec.
Thanks xmarine for the help.
Posted on Feb 12, 2009
Thanks for the solution! Be sure and press the vol- on the TV, not the remote, along with PIP on the remote. Had this TV for about 6 1/2 years and never knew how to rest it until now!
Posted on Jun 17, 2010
  • Harleymloren Sep 10, 2011
    I have a Panasonic LCD TV model PT-50LC13. The procedure I used to reset the Lamp to 0 is: Simultaneously press the vol- on the TV (not on the remote), along with PIP on the remote. After about 5-10 seconds a message will appear indicating the lamp timer was reset to 0. Easy. Good luck.
My remote don't have pip button what is split key button? I pressed volume down and play didn't work
Posted on Sep 04, 2010
Everything above is exactly correct but not with a universal remote. One more thing for the males who don't like to read directions without pictures.... "Put the TV COMPLETELY back together..."! That means... put the lamp guard back on and lock it! Then you can follow all the above directions to reset lamp time. You men...just can't follow directions... What would you do without us females.. hee-hee...
Posted on Jun 07, 2008
The above is correct. I own a Panasonic PT-52LCX15 and the proceedure worked but I had to do it three times before it took. So, hang in there.
Posted on Apr 11, 2008
The suggestion of the VOLUME button and the PIP BUTTON for 5 SECONDS worked. thank you.
Posted on Jun 20, 2008
  • PHAB Aug 22, 2012
    I have the PT-40LC12 and this one worked for me. Thanks.
What if you do not have the factory remote? any other options?
Posted on May 27, 2008
How do you reset lamp meter?
Posted on Nov 02, 2008
Working fine then went off with a click and flashing blue light. Powered it off and on.picture came on with no sound after couple of minutes went of again in the same way 32`` 209 teknika
make this test and fix it. God bless you
You simply need a screwdriver (Phillips-head) and then follow this guide:
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
  • Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
  • Use your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
  • Check the fan. Once the television is turned off, it is just normal for its fan to become louder. A projection TV actually depends on its lamp, which requires cooling so that it will not prematurely burn out. If the room where your TV is placed is very hot, the fan would also continue to run.
Replace projection lamp. To properly do this, make sure that the lamp's bulb has cooled down and the TV is unplugged. Carefully remove the cover of the lamp's compartment using your screwdriver (Phillips-head). Unscrew the sealed part of the lamp that can be found at the television's rear part. Take away the old lamp cartridge and then insert a new one. Seal the lamp with screws, replace its cover and then screw tightly.
Nov 03, 2013 | Televison & Video
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
I HAVE A SAMSUNG SP46L6HV REAR PROJECTION HD DLP TV AND IT HAD MAKING A NOISE BUT NOT THAT LOUD AND THEN ONE DAY IT WAS ON AS NOMAL AND JUST WENT OFF , MY HUBBY TOOK THE BACK OFF AND SAID THE LAMP WAS...
Before it went out, was the sound like a fan or high pitched in nature?
Lamp can be removed (is is customer replaceable) to see if shattered inside.
I suspect a bad color wheel, which is not hard to replace. See attached photo of color wheel.
Examine lamp and if not shattered do not buy one to try.
I am here to help you for free.
Comment here and I will assist you.
SD TECH
Sep 16, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Jan 29, 2010 | Panasonic 52LCX1516 52 in. Television
I've already replaced the bulb on my Panasonic television model number PT52LCX66, but I can not get the message of the screen that tells me to reset the hour meter lamp. How do I reset the the hour meter...
Turn off tv. Hold vol- on tv and tv/video button on remote same time for 5 seconds. Select lamp time use vol- on remote to reset to zero. turn off tv to remove serv menu.
Nov 24, 2009 | Televison & Video
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
6,147 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
