Question about Exercise & Fitness
How do i tighten and centre the belt on POWERTREK
How do i tighten and centre the belt POWERTREK ULTIMATE X
When i run on this treadmill it makes a sceeking sound any way i can solve this problem?? really gets on my nervs when doing my work outs!!!!!! HELP
Posted on May 23, 2011
    President:
  • 832 Answers
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
Posted on May 14, 2010
I purchased a Manual Powertrek treadmill possibly approx 5yrs ago,lost the manual and there is no part number on the treadmill,how do i contact Powertrek direct,thankyou
go google and type in ---powertrek-- find their page that has a "contact us" section click on that and there should be an address, phone number, fax number and e-mail address.
Nov 07, 2016 | Health & Beauty
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    How to reroute the drivibg belt or fan belt
    Hi,just inline the crankshaft to the top dead centre marks,then check that the camshaft marks line up,if they dont line up then turn the crankshaft pully again untill the camshaft marks line up,slacken the timeing belt pully adjuster take belt off and replace with new one,tighten the pully adjuster back up,now put a spanner on the crakshaft pully and turn clockwise untill the top dead centre marks and the camshaft marks inline if they dont then slacken the ajusting pully inline marks again and try again,if marks do inline ok then you are ready to start the car.
    hope this helps good luck.
    Feb 25, 2015 | Cars & Trucks
    Powertrek treadmill jerks to start and straight away to stop repeatedly. what can be a problem?
    1) ;LUBE THE DECK BELT very well, this a sign for a deck worn.
    2) lube the rollers bearings too.
    3) Measure the input voltage motor, if there are the motor need repair
    4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
    see the diagram
    Good Bless you
    Jul 03, 2012 | Exercise & Fitness
    Belt is slipping, how do i tighten it ???
    This is dinesh from AADHI FITNESS SERVICE CENTRE...
    Search for the details in justdial india...
    Need some allignment and service for ue machine...
    Contact no is 9986202487
    Jul 28, 2010 | Proform 530 Treadmill Walking Belt
    My belt needs to be adjusted. I believe it needs ...
    If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt (2 to 3 in.) off the walking platform. Be careful to keep the walking belt centred. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
    May 20, 2010 | Lamar L-1300 Treadmill by Star Trac - !
    Washer fills and empties,but agitator does not move in centre of machine? Washer goes through timer cycle, I suspect drive belt is broken?
    If it will not spin either, but the motor does run, the motor coupler has failed. It is also possible the transmission has a problem, but the motor coupler is more than likely the problem. This model does not use a belt, it uses the coupler instead.
    Jan 06, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    I need to replace my timing belt on my hyundia elantra 2003 with 1997 cc engine
    Dear Friend
    Removal: Support engine: remove -engine mounting, auxiliary drive belt, water pump pulley, crankshaft pully bots & crankshaft pully, timing belt covers....turn crankshaft to TDC on No 1 cylinder, ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket & balancer shaft sprocket timing marks lighned. Pls note: Timing marks on camshaft sprockets should align with cylinder head uppter face, dowl pins on camshaft sprockets should face downwards....Slacken tensioner botl. Move tensioner away from belt & tighten bolt.
    Remove: automatic tensioner unit bolts, automatic tensioner unit, timing belt, crankshaft bolt, crankshaft sprocket, crankshaft sprocket guide washer...slacken balancer shaft belt rensioner bolt, move tensioner away from belt & lightly tighten bolt...Remove balancer shaft belt.
    Installation:
    ensure timeing marks aligned.Note: Timing marks on camshaft sprockets ahould align with cylinder head upper face, exhaust sprocket mark is on recess but inlet sprocket mark is on tooth. To check oil pump sprocket positionded sorrectly: remove blanking plug from cylinder block, insert 8mm diameter Phillips screwdriver in hole. ensure screwdriver is inserded 60mm from face of cylinder block. If screwdriveer can only be inserted 20mm-turn oil pump sprocket 360". Inset screwdiver again.
    Fit balancer shaft delt in anti-clockwise direction starting at crandkshaft sprocket....Slacken balancer shaft belt tensioner notl, turn tensioner clockwise to tension belt. Tighten bolt to 15-22 Nm... Applu thump pressure to belt at tentioner, belt should deflect 5-7mm. If not: Repeat tensioning procedure.... Install - chankshaft sprocket guide washer & crankshaft sprocket.
    Thighten crankshaft centre bolt, tightening torque:110-130Nm. Please note, ensure crankshaft sprocket guide washer is fittet correctly. oil threads & contact face crankshaft botl before fitting.
    Sep 21, 2009 | Hyundai Elantra Cars & Trucks
    How do i use the kirby shampooer
    I'ts a little fiddly - but pretty good when it gets going.
    Remove bag from bottom connection by swinging outwards untill it clicks - then remove upwards. Unclip at the top also.
    Undo belt by rotating centre pop-out handle and then top snib.
    Assemble parts required - and clip onto the front - roller is underneath - but belt has to feed over the hoover's spindle. Rotate centre assembly to pick up the belt and pull it - then fit and reverse direction to fit belt into machine.
    The pot is for the foam solution - make up solution and attatch pot. There is a large clear hose that joins pot to shampoo base.
    That'sabout it.
    Starting machine pushesair through pot - making foam which is then ducted into the roller area. Waste foam collects on the top.
    This is from memory - so If you get stuck - ask again - I may be able to find the manual for you.
    Aug 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
    Exercise & Fitness Logo
    310 people viewed this question
    Top Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
