Question about Car Audio & Video
Wire radio installing factory radio in 1982 300SD (mercedes). The exsisting wires are chopped up. The radio I have is for this car and has the connectors for it still pluged into it with enough wire to make the splices. The problem is things don't seem right, that is the wire guages are different and at the car end of the wires there are two wires of the same color when I only need one to go to the radio. This situation is true for about 3 sets of wires. I need to see a schematic of this area.
When I foud out you wanted money I went to " JUST ASK " site. I don't mind paying, but I do mind being tricked ! You wasted my time and yours by misleading me to believe this service is free. Oh ya, if I want to wait for who knows how long to get an answer that I can't trust, it's free. In that case your still wrong because you say get answers from an expert but you don't say it will cost you until time and effort has been given on the part of the sincere customer. If you were honest in the begining fefore I took the time to type out the problem (instead of tricking me) I would have tried you out. I also believe that when a company does business this way it's a representative of the founder. (DISHONEST)
Posted on Mar 30, 2008
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
Jan 03, 2015 | 1998 Ford Ranger
How to replace radio in 2004 blazer
REMOVE THE BEZEL IF ITS NOT SCREWED IT WILL BE CLIPPED SO BE GENTLE AND FIRM WHEN REMOVING AS NOT TO BREAK IT. WHEN YOU REMOVE THE STEREO ENSURE YOU PURCHASE THE INSTALL KIT FOR YOUR YEAR AND THE WIRING HARNESS. THEY CAN BE BOUGHT AT WALMART EBAY WHERE EVER. THE HARNESS IS MADE FOR THE VEHICLE SO IT PLUGS INTO THE EXSISTING WIRING AND YOU CONNECT THE WIRES FROM THE NEW RADIO TOGETHER . THE COLORS SHOULD BE THE SAME ZIP ZIP DONE! ALSO THERE ARE VERY GOOD INSTRUCTIONS WITH THESE KITS. GOOD LUCK
Apr 30, 2014 | Ford Ranger Cars & Trucks
How to install aftermarket radio
installing radios into electronic controlled cars can be a real nightmare as the wrong wires used creates many CPU problems . Best have it installed by professional radio fitters at the shop where you bought the wireless and save your self a headache.
Apr 26, 2014 | 1992 Mercedes-Benz Mercedes Benz 300 Class
How do I hard-wire an 89 mercedes benz 300te to an aftermarket radio?
this helped me on my maxima ...but had to destroy factory radio to get look at the back side of mother board .....dont try it..worked for me tho
Aug 16, 2012 | Cars & Trucks
Witch wireing harness do i use to install radio sistem
there should only be one harness for the radio system. When you took the old one out, it should be sitting right there. It will be a rectangular (if my memory is working right) and have a female end. you should have multi colors on it. red, black black with a white stripe, blue,green and orange(maybe purple, usually for speakers). if you don't see it right away, shine a light in the radio hole, and look down, it may have dropped. If it was not the factory radio, and someone put a different one in, they have plug adapters, so you don't have to chop and splice wires. they just plug in. Is this what you are seeing. let me know, I may have to look it up for you.
Jan 13, 2011 | 1996 Nissan Sentra
The wires in my 1993 ford taurus have different color wires than my new radio
I would get a wiring harness adapter for your car. You can wire your stereo to the harness and then plug it into the car's exsisting plug.
May 21, 2010 | Car Audio & Video
1997 mercedes benz slk 230
Car Radio Battery Constant 12v+ Wire: Red/Green
Car Radio Accessory Switched 12v+ Wire: Pink/Yellow/Green
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Gray/Blue
Car Stereo Antenna Trigger Wire: Blue/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under right footwell carpet.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/Brown
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Yellow/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): N/A
Left Rear Speaker Negative Wire (-): N/A
Right Rear Speaker Positive Wire (+): N/A
Right Rear Speaker Negative Wire (-): N/A
pls rate
Dec 13, 2009 | 1997 Mercedes-Benz Mercedes Benz Sl Class
'04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Sep 05, 2009 | Car Audio & Video
What color is what for the radio wires i have like a atapter
your car should have an ISO connector, all newer radios also have ISO connectors, one for the 8 speaker wires and one for the power block, they cannot be connected wrong.
If on the other hand some muppet has chopped off the connectors instead of using a proper converter connector then you should reinstall new ISO connectors.
You will need:
A 12v test light or a multimeter set to 120vdc
some masking tape to make labels and a ped to mark the labels.
A quick test to establish the correct wires is.
using your 12volt test lamp or multi meter, find a wire that is live when ignition is off, this is your +30 live, now switch on ignition and find one that is live, this is your+15 live, now switch on the lights, is there another live? this is your lights or dimmer wire. with the lights and ignition on connect the live lide of your tester to the +30 wire and find one that is earth, (you should be running outof wires by now anyway, this si your earth or ground wire.
The speaker wires will probably be seperate and if you have a bunch of 8 wires, that's them.
you will find there is a prime color and another with the same color but with a trace, so make into pairs, ie, red and red/white, green and green/white etc.
using a 1,5v AA battery touch each pair very briefly in turn, the corrisponding speaker will 'pop', mark up front left etc.
There ya go, all sorted.
Mar 07, 2009 | 1987 Mercedes-Benz Mercedes Benz 190 Class
I would like to know what harness & Kit i need to install radio
Metra is the only manufacture I use.
#70-1858 Wire Harness
#99-3101 (with A/C) #99-3102 (w/O A/C) Kit
Also a mini gm to standard antenna adapter is required.
#40-GM10
Jan 22, 2009 | 1989 Chevrolet Beretta
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
