Question about Refrigerators
Fridge prolems Electrolux ERE 3500
Hi
I have a problem with an Electrolux fridge ERE 3500. There as a clicking noise coming from the top where the control electronis are ... once click per second. This was happining at night for about one hour but has started to occur constantly.
Thanks
David
  • 1 more comment
  • giszo May 05, 2008
    i have a same problem.
    what do i do ?
  • VSV1 Jul 08, 2008
    I have the same problem, one click per scond.
    What is this for a problem, how can I repair it?
    Vladimir
  • Anonymous Apr 20, 2009
    same
Disconnect the power cord (or switched power off) and wait an hour or two until compressor has cooled. When you now switch the power on, the clicking is heard only once and compressor starts (weak noice and vibration noticed). When compressor gets warmed, the compressor will stop and clicking starts again (clicking comes from electric circuits when compressor is switched off and on repeatedly, but it will not start because it has stucked - this is typical fault in old compressors said maintenance expert to me). Buy a new fridge.
Posted on Jun 16, 2009
  • PeLi49 Jun 23, 2009
    See symptoms in Solution #3. One more symptom is that door light is also flashing. If you have these symptoms, the gray capacitor of 1 yF K 275 Vac must be changed. At least it helped in my case.
I have got a clicking problem on the top board of my Elextrolux ERE3000 fridge.
This sound is generated by the motor starting relay which is piloted by a 1 micro-farad capacitor.
I changed this capacitor and my fridge works again.
When you've got such repetitive behavious it is often due to a capacitor. The motor fridge was hot, which meant it was not out of service.
Thanks to some Fixya experts
Posted on Aug 21, 2011
Problem is a circuit board on the top of the fridge. Every single one of these get the same problem. You have to change the circuit board and also the temperature sensors, because the new board is different.
Now unmounting the fridge isn't a big problem if you're a bit handy. If you know electronics chances are you can fix the old cicuit board. In my opinion it's one or some capacitors causing the problem. I bought a new circuit board since I need the fridge and don't have the time to fix the old one.
Posted on Oct 01, 2008
No it is a power problem.
Posted on Jun 24, 2008
I belive its the thermostat
Posted on Jun 18, 2008
Electrolux ere 3500 problem
Ok you have a faulty relay on the compressor very easily fixed, tell your repair man whats wrong then they cant rip you off.
Nov 16, 2013 | Refrigerators
Electrolux Side by Side Fridge-Freezer ESE6108WA - freezes food in the fridge
hi its sound thermostat problem not click off when the temperature reach to the set point ,need to replace it.
May 14, 2012 | Electrolux Refrigerators
Fridge not getting cold
With a top freezer the cold air comes from the freezer down into the fridge. It uses a fan to blow the air down. It's possible that the fan is burned out. Does the fan come on if you turn the temp. to the fridge to colder? If not, then that may be the problem. The fix is not too easy, but can be done by an experienced do-it-yourselfer.
Mar 11, 2012 | Electrolux ER7926B Bottom Freezer...
Hi, we have a caravan which has an electrolux RM360 gas/electric fridge installed. There is a very weird smell coming out when the fridge is turned on. Its like an ammonia smell it is really strong,
Travel refrigerators use an ammonia coolant instead of freon. So the smell is telling you that you have a leak in the sealed system.
Suggest you look for a replacement fridge OR a rebuilt unit because that is usually cheaper than taking it to a service center for repairs.
Jan 25, 2012 | Electrolux Refrigerators
Electrolux commercial fridge with bad noise now ice
easy replace it bearings have failed
Jun 02, 2010 | Refrigerators
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Squealing noise coming from refrigerator/freezer
The freon is evaporating in the tubing, this is common problem, You can report it to Frigidaire and the might be able to send out a tech to adjust the filter drier or add som nitrogen to the system. And when he comes tell you that I don't know what I am talking about, I am an authorized servicer for Frigidaire and have been an appliance repair tech for 38 years. This info comes directly for Frigidaire Technical Assistance dept.
Dec 17, 2017 | Electrolux Refrigerators
Fridge keeps making "clicking" noise and will not get very cold
the clicking noise is probably the unit trying to start but it cant because its too overheated,try turning it off for about 30 minutes to cool the compressor down,then put the thermostat at 3 for the fridge and not the coldest for the freezer and leave it there for a few hours to stabalize the temperature and see what happens.
May 09, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerators Logo
1,837 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
