Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
Flickers on and off
My LCD too, flickers on and off, I have gone to the safe mode using F8. However, I am unable to see the screen long enough to scroll to the right line. How do I go to the right section without seeing the screen or is there another way to get there? I have a laptop but I wouldn't know how to connect it to my laptop and have the monitor connected at the same time? I am optimistic that the solution that was mentioned on11/10 could work if only I can access the screen long enough to move forward. thanks I had the same problem and replaced the C922 cap. It's now a few months later and the problem is back, guess I'll try the higher voltage cap.
  • 3,037 Answers
It is unable to process quick rendering from a bright scene to a nearly pitch black scene. Can you connect another monitor to the computer to do the following.
Check your refresh rate (under desktop properties if using windows) and try setting it to 60Hz. LCD monitors have a slow enough "decay" rate that you will not see any flickering at that lower rate like you would with a CRT monitor.
If it was a Dell monitor from (but not including) 24" and below, it could be what is called a "CCFL failure" which is just when the lamps on it are defective or the main board inside. If it flickers and turns off but the power button is still on... I would give it a 90% chance that it is a "CCFL failure". If it only flickers but doesn't turn off, test the main board before replacement, but there is a strong possibility that could be it. If it is 24" and up, well it could still be the same thing, but it's a little more complicated. DO NOT TRY TO DO IT YOURSELF... or you might wanna consider getting a new monitor. It doesn't matter how careful you are, you can potentially mess it up. Electrostatic Discharges can make a French Fry out of your main board. Which would make it useless... obviously. Well, the best of luck partner.
Posted on Mar 29, 2008
  • 19,396 Answers
You can try lowering resolution on your pc and seeing if you still have the problem. You will need a spare screen to fix your problem, even an old crt will do.
regards
  • Ginko
    Ginko Mar 29, 2008
    Well, there are two different problems posted here. If you are the one who replaced the C922/C822, you may have a problem that it is not related to the C922, just test the capacitor. Check nd test also the monitor power unit.
  • 818 Answers
I have the same monitor and the power light was blinking on and off regardless of whether it was plugged into a source or not. I could see an image of the desktop cycle on briefly in conjunction with the power light. I repaired my monitor by changing out a 1000uF/16v cap (C922) and everything is working great."
I would suggest changing the caps to a higher voltage rating if you have one that will fit. I installed 35V 1000uF Cap for C922. My unit also had a 470uF cap next to C922 that was bulging so I changed it also.
Its an easy repair if you can solder at all. The hardest part is getting the back cover off. Remove the 4 screws that hold the base bracket in place and carefully slide it out. Then the other 5 screws on the back. (One under base plate you can't see till base is off.)
Then you can remove the metal sheild and acess the PCB's. 2 Screws and the HEX standoffs at the VGA port need to be removed and it will slide off. The inverter board is the one on the left.
Even at Radio Shack prices these caps should cost less than a couple bucks. I took mine off a couple junk boards I had. Replace any that are bulging at all.
Many thanks to the person that threw this monitor in the dumpster for scrap metal at our local tranfer station. Works great.
  • Liquid Video Master
  • 13,433 Answers
Are you sure its the only cap witch is faulty? maybe another one has broken down / about to.
I have acer keyboard KG-0766, but usb is gone. if I buy a new usb?
what are you referring to usb is gone ?
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
hope it helps
Aug 23, 2012 | Computers & Internet
Changed VGA settings. When computed boots up I get a black screen. A small box displays the MSG - MODE NOT SUPPORTED. Is there a way to change the mode from the TV?
1. Let's power the computer off in order to boot it into "safe mode."
2. Restart your computer and start pressing the F8 key on your keyboard.
3. You will be presented with the Windows Advanced Options Menu that contains several options to choose from. In this case you will scroll down using the down arrow on your keyboard to the option, "Safe Mode" then press the "Enter" key on your keyboard.
4. The next screen should display "Please select the operating system to start:" typically the name of your version of windows will be displayed and highlighted in white, I recommend you just press "Enter" on your keyboard at this screen.
5. Now you will see a bunch of white writing scrolling about your screen and after a few moments you should be able to login to Windows.
6. You may receive a prompt asking if you really want to boot into Safe Mode. Choose Yes.
7. Once Windows is fully booted, you will be in safe mode.
8. Now right-click on the desktop
9. Choose "PROPERTIES"
10. The "DISPLAY PROPERTIES" menu will come up, then press on the "SETTINGS" tab
11. In this tab you will see a slider bar that can be slid from left: (Less) to right: (More). Slide the tab to the left toward the "Less" option. After positioning the slider to a lower screen resolution be sure to press "APPLY" then "OK" on the bottom of this menu
  • Usually a 1024×768 screen resolution will be sufficient for most monitors.
12. Now reboot your computer as you would normally and that lovely "VGA not supported" message should be long gone.
May 09, 2011 | Insignia NS-LCD19 19 in. LCD TV
How to put toshiba f20 into safe mode
when the computer first starts to boot up tap the f8 key this should bring up the options for booting into safe mode if not try f5.
May 02, 2011 | Computers & Internet
Unable 2 remove viruses and unable to uninstalling AVG Anti virus.
There is an AVG removal tool here.
I would suggest MalwareBytes to remove viruses.
Mar 01, 2011 | Computers & Internet
Hi, I need to know how to start-up in safe mode.
During boot up repeatedly press f8.
Or within Winows press start >> Run >> msconfig >> press Boot tab >> check safe boot.
Jan 02, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
How to go in safe mode?
to go into safe mode, turn on your computer and constantly press F8 immediately. You will press the F8 button at the first black screen, that is, when your computer displays its log.
While pressing the F8, a windows option will be the next screen to appear, amongst the windows option, you will see safe mode there, use your keyboard arrow key to scroll to safe mode and press enter.
By now,your computer should be loading on safe mode.
Good luck.
May 18, 2010 | IBM ThinkPad R51 Notebook
The motebook load find but the screen just flicker
Try accessing safe mode by pressing the F8 key on boot up...if same may be monitor / mobo / mobo driver.
Try another monitor plugged in to it. If fixed its the LCD monitor.
Apr 13, 2010 | ASUS Eee PC 900HD Netbook
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Laptop LCD problem
hi, have you tried switching the screen mode, i think its FN button and F4, failing this you may have a faulty LCD controller chip, messy to fix unless you bring it some one who is repetable at fixing laptops...
Feb 19, 2008 | HP Pavilion dv6000z Notebook
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
35 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
