Question about Plumbing
Shower wont fully shut off ,how do you replace or clean out valve ,its a exposed single lever thermostatic mixer valve,6 months old
  • 34 Answers
You have to first turn off the water to the whole house and open a faucet upstairs and downstairs to properly drain down your pipes (less messy).
Take the handle off with an allen key (hex). Undo the 2 screws that hold the faceplate on and it will slide off with the sleave. You will find a brass valve body with a lock ring which screws off by hand. It may be tight for half a turn and should then spin off. If it remains tight you still have pressure behind it and are about to get wet (go make sure the water is off and drained). The cartrgidge should just slide out, if tight give it a turn and it will pop out. Take it to any hardware store and get a new one (many stores give replacements for free if you give them the cartridge). The cartridge will be set to a low temp for safety and you may want it to be hotter. The adjustment is on the front of the valve. Look for the little notches on top of the cartridge to adjust.
Also note that one side of the cartridge says "hot side" on it. Take a look in the valve body for debrise that may cause the same problem. Now just replace all the parts and enjoy.
Posted on Jun 08, 2010
Could my shower be airlocked
No, the ball valve is likely rotated 180 degrees from where it should be. Shut off supply and verify the hols in the stainless ball are facing to the same side as the seals are.
Or the supply valves to the shower are still shut off.
There is a small possibility the pressure balancing valve is stuck closed.
Jan 15, 2012 | Delta & Single Handle Shower Faucet
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
I installed new moen shower valve i tested it before i put the walls up 6 months later finaly got done with bath room no water comes out now
During construction did you perhaps close off a shut off valve within the water line and not reopen it? If not do you hear anything at all when you turn the shower faucet on? Let me know.
Jul 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
How do you switch out the single lever dial on a delta shower fau
Hidden under the lever is a little hex screw. Use an appropriate hex a.k.a. "Allen" wrench to remove the handle. You might want to shut down the water service first to save your shower until later.
Mar 16, 2010 | Delta & Single Handle Shower Faucet
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
Moen shower head drips. Single lever shower only. Installed by home builder about 2001. How do I fix the drip/leak
Probably need to remove and replace the cartridge. Often sediment will tear part of the o-ring or seal on the cartridge and cause this problem...
varies by model, but generally, remove the cap on the knob, unscrew the knob, remove the keyed sleeve, remove the round trim plate & shut off the service stops (verify they are fully closed by pulling out on the valve stem) next remove the retaining clip (needle nose and be gentle) that holds the cartridge in place, then pull the cartridge straight out with vice grips or similar (or get a puller). clean the cartridge, flush out the valve body by slightly opening both service stops, reinstall cartridge and clip, open service stops and see if it still leaks. if it does, take your cartridge to the store (any reasonable HW or plumbing store should have a replacement) and get a new one. then reverse the process to reinstall.
If you send me the model I'll get you more specific instrucitons and pictures...
Oct 10, 2009 | Moen Home
Slow leak old delta
The brass cap unscrews and yes there are replacements. You can find them at any home improvement store.
Sep 14, 2009 | Delta & Single Handle Shower Faucet
WATER IN TUB HOT, THEN TEMPERED
It sounds like you have an anti-scald mixer in the system that needs to be adjusted.
Jul 26, 2009 | Paini Spa Rubinetterie LaToscana 3 Piece...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
