Question about Canon imageRUNNER 2200
Copier jamming/copy printing sideways
Our copier is jamming up and what is printing prints sideways
  • 1,110 Answers
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
Posted on May 13, 2010
How can I print sideways?
Instead of hitting PRINT, there should be an option listed as PRINTER SETTINGS or better yet, PREVIEW. You should see an option for landscape or portrait and various other settings! Hope this helps! :-)
Jul 21, 2014 | HP Deskjet 3512 Inkjet Multifunction...
When i start to print it always gives me paper jam and print fain
Clean beeneth copy glass and even the laser unit.
How many copies do you have with present drum unit?
If over 50000 copies change the drum too.
May 25, 2010 | Canon iR 2016i Black and White Copier
Large paper printing
12 x 18 is the largest size paper that can be used on this copier. If anything larger is used the machine will jam. The copier uses a series of paper sensors to track and time the paper throughout the printing process. The max is 18 inches anything over that cuase the machine to jam.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
Prints are only at 80%
make sure your paper is not set to "ltr-r"or "letter r" which is the same size paper, just turned the other way. The control panel should show you the paper size its set for, or you can turn the original sideways if the platen/target glass allows for this size. This machine is a digital copier, so it should be able to turn it the proper direction unless its programmed for "ltr-r" copying.
May 26, 2009 | Sharp AR-164 Copier
Canon Copier MF 6530 stopped printing after a paper jam, everthing else works fine no error code just won't print. I have remove the cartridge shook it and still nothing. Do you have any suggestions?...
I would reset the Photo conductor unit. It will have a Green drum in it. I would make sure it is set in the machine all the way, and that the drum door opens completly. BLANK copies are and indication the paper has NOT touched the drum to recieve an image.
Apr 04, 2009 | Canon imageRUNNER 5570 Copier
"Jammed" message
Try new paper.Damp paper causes all kinds of jamming prob.
Jul 13, 2008 | Copystar CS-2030 Copier
Won't print
Have seen something similar when the user was printing labels and one came off. There was a jam, but you couldn't see the offending paper, and it was stick as well. Got it out carefully, but it wasn't easy - did not want to take the thing apart
May 29, 2008 | HP Officejet 5610 All-In-One InkJet...
E350 misfeed on print/copy 2nd page
Does this happen from all cassettes or only one? What are you getting for a jam location??
May 11, 2007 | Toshiba e-Studio 350 Copier
Canon imageRUNNER 2200 Logo
273 people viewed this question
old marine
old marine
