Question about HP Compaq Presario F730US Notebook
Compaq presario F730US frozen. Removed battery to reset system. Now boots up but get "new hardware found" error message. Now no applications functioning and error message comes back again and again. Using VISTA Home edition. There are no new devices plugged into the pc. The pc freezing and having to remove battery has been a problem for a while now.
  • 32 Answers
If resetting the bios does not work, you either got a nasty virus, or the hardware has an issue. my suggestion, if resetting bios is not the solution, backup your data and reinstall windows
Posted on May 17, 2010
Testimonial: "Thanks for the help. Will try this and soultion one shortly and let u guys know what the outcome was."
  • 808 Answers
Update ur windows scan ur pc with some gud antivirus and use reginout regcleaner i hope it will solve ur problem
Posted on Aug 19, 2010
    Scholar:
  • 59 Answers
You need to update the BIOS of the pc which would resolve this problem...
Here's the link for updating the BIOS Version of the system.
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38173.exe
Run the file which would shut the system down...
Restart the computer after a couple of minutes to check the functionality of the system..
Hope this works
Regards
KEN
Posted on May 13, 2010
4 Suggested Answers
SOURCE: hp dv2000 error code 104- unsupported wireless network device detected system halted
The user has not described the operating system in use.
However this problem generally occurs due to incompartible hardware. in this case it is ever stated. ie. Network interface Device. I suggest you disconnect the Network devices including cables, then try to reboot.
If not descibe how far the booting process gets and type of network hardware connected and operating system to your system
Heruless
Posted on Nov 07, 2008
  • 230 Answers
SOURCE: 104-Unsupported wireless network device detected. system halted. remove device and restart
The problem is caused by a card that is either not built for the machine or is corrupt. This is not a driver issue as this message comes up in the POST (Power On Self Test) this is before any driver is loaded. The reason that this happens when a network card is replaced is because HP/Compaq laptops have a whitelist of allowed cards built into the bios. If the cards vendor and device id don't match one on the list they don't allow you to run it. This is simply so you have to line the pockets of HP spare parts for somthing 10 times more than what it is worth. The only solution is to flash your bios with a modified one to remove the white list. This is a very risky operation and could brick your machine. If your getting this error and have not changed your card the likely reason is corrupt card or the bios has somhow become corrupt. Good luck on this issue.
Posted on May 06, 2009
  • 119 Answers
SOURCE: Compaq laptop nc6230 freezes on startup with XP SP3
hello
you reis goninstall your system factory setting and your problem e i advise to u use ur laptop very softly
you can give me high rating for this help
please
Posted on Oct 25, 2009
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Compaq Presario F730US doesn;t recognize the touchpad. Works with an externalmouse only. How do I get it or recognize the touchpad?
Your problem that you are experiencing is either hardware related or software related.
Hardware related in the sense that it is not connected or the actual touchpad it faulty.
Software related in the sense that the drivers need to be reloaded.
A technician will be able to diagnose the problem source, claim warranty support if you can!
Thumbs up!
damnor01
Jan 30, 2011 | HP Compaq Presario F730US Notebook
Compaq Presario F730US PC Notebook: i installed hp wireless assistant. but when i open...
I used to have internet wireless connection problems and finally realized that F761usa front wirless swich was changed frequently, even I believe I never touch there.
May 17, 2010 | HP Compaq Presario F730US Notebook
My wi-fi does not work on my presario f730us, I changed my wi-fi card and nothing and my wi-fi on my other computers work so I do not think it is my router/network, Can you help ? Thanx
Click Start > Control Panel > System
Click "Hardware" tab
Click "Device Manager" button
Is the card listed in manager? If so right click on it and update the driver.
Post back.
Mar 16, 2010 | HP Compaq Presario F730US Notebook
Will not boot up
No lights or anything? Not booting up can be quite vague. If there are no lights then probably need new power supply/motherboard. If it were the battery then more than likely it would work when plugged in.
Jan 20, 2010 | HP Compaq Presario F730US Notebook
Compaq Presario F730US, Will not Power Up
Try to find a BIOS Update. To check that BIOS update is avaialble, visit http://www.compaq.com select your product and find the BIOS update in support or download section. It may solve the problem. (ehteshamhusain@gmail.com)
Jul 20, 2009 | HP Compaq Presario F500 F700 and G6000...
Save to disk file not found run ph disk for info
the cmos is under the aluminum of the keyboard try to remove it carefully its too easy
Jul 16, 2009 | Compaq Presario 1275 Notebook
Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Jun 17, 2009 | HP Compaq Presario F730US Notebook
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
Laptop will not start
It's possible the video card is burnt out from over heating.If it is you need a new motherboard.
Jun 01, 2009 | HP Compaq Presario F730US Notebook
HP Compaq Presario F730US Notebook Logo
363 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
