Question about GE WDSR2080D Top Load Washer
GE heavy duty washer
We bought this used. When it spins it jumps around and pounds really hard
Thanks
Donna
  • 638 Answers
Also, flip the washing machine over. There should be a large block of concrete held in place with bolts. The original owner might have removed this to make the unit easier to lift and might not have replaced it. If it is missing, this will also cause the machine to jump around unevenly.
Posted on Apr 25, 2008
    Problem Solver:
  • 8 Answers
Make sure clothing is properly distributed in drum. Try this but need more info as to weather it spins and bump or weather or not it stays in one place and bump.
Posted on Apr 03, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Washer will not do final spin
If the washer will spin between wash and rinse cycles and on another cycle like perm. press or heavy duty, then the timer is probably bad. If everything works on another cycle, you can use the machine while you save for another one, or can find a new timer for the one you have. Best of luck
Mar 21, 2010 | GE Washing Machines
My Kenmore heavy duty washer runs does not spin
check out the security switch located at the lid , it could be defective , with a multi meter check for continuity, thanks AJ
Dec 12, 2009 | Computers & Internet
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore washer out of balance
go to sears.com and find the parts listing for the 110 model number you have listed above .http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=8mJfynqZfmsdSyTnd9kaQw**.shcapp3005?modelNumber=110.16502694+&pop=flush
You might need one of the springs. unplug the washer and take the cabinet off first. look around for broken or missing parts
May 12, 2008 | Washing Machines
Extremely Load spin cycle
Mine was doing this and my husband tightened the huge bolt on the back of the drum. This is where the belt attaches. Evidently this bolt when loose can cause that outrageous sound.
Mar 03, 2008 | GE WSXH208A Front Load Washer
GE WDSR2080D Top Load Washer Logo
256 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
