Question about ASUS 1101HA-MU1X-BK Netbook
I'm having trouble opening my asus eee pc from hibernation mode
Hi. i'm having trouble opening my asus eee pc 1101ha from hibernation mode. it doesn't turn on with pressing the power button, moving the mouse, opening the lid, or pressing any key. any idea how it can resume from hibernation mode?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Ok,
1- disconet the power supply
2- take the bat. off
3- now press the power button for a few seconds (20)
now put only the power suply and reboot
Posted on May 13, 2010
Asus 1101HA battery isn't charging
Is the battery a Nicad or Li-ion type, if Nicad, then that is the culprit.
Nicads are notorious for retaining memory from last charging, therefore the next charge starts from the last time it was charged. Li-ion batteries don't have a memory issue, so they recharge fully.
I hope this has been helpful.
Regards,
Peter
Feb 21, 2013 | ASUS Eee PC 1005 10 Inch Series 1101HA...
Tip
Review Asus Eee PC 1101 HA
asus-eee-pc-1101ha.jpg The Eee PC 1101HA netbook with a 11.6-inch display. For this and its characteristics could be defined almost a notebook. Obviously, a larger than normal netbook weighs more, but the Asus Eee PC 1101HA is a netbook with mobile calling. Asus Eee PC 1101HA promises up to eleven hours of PA3420U-1BRS battery life, thanks to the Intel Atom Z520 chip.
Homes and Design
The Eee PC 1101HA has the same form "shell" 1008HA Asus Eee PC. The case is polished and its shape makes it particularly elegant netbook. We noted that despite the gloss paint handprints not remain imprinted on the case easily. This Asus Eee PC 1000H is available in white pearl, black and pink crystal.
The hinges Eee PC 1101 HA self-locking (no mechanical locking) but well hoods that limits the opening angle to a maximum of 130 degrees, this makes little netbook fittings for use legs. The screen however is quite stable.
Autonomy
Asus EeePC 1101 declares that HA is able to provide even eleven hours of VGP-BPS2C battery life. Indeed, the netbook can reach eleven hours, but with the six-cell DV1000 Battery and without Wi-Fi active since our test Eee PC 1101 HA has worked from time to time reaching autonomy of 10, 48 hours. The test was performed with a non-intensive use and without wireless enabled. With wireless enabled netbook's Inspiron XPS M1710 battery life decreases by about three hours.
Weight and Dimensions
The amp 11.6-inch display makes the netbook a bit 'pesantino (1.38 kg) obviously increases the overall dimensions: height 21.80 cm, width 28 cm, depth 19.60 cm.
Judgement
Cast a netbook for mobility, thanks to long HP dv4 Battery life, good performance that does not disdain. We can define Eee PC 1101HA netbook complete. In fact, the hardware equipment enables to easily perform common office work in comfort. With excellent value for money (currently about 360 million) this netbook is among the best in its class.
on Apr 21, 2010 | Computers & Internet
ASUS 1101HA HARD DISK LOCKEED NEED PASSWORD
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is availible) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Sep 23, 2012 | ASUS Eee PC 1000HE Netbook
Asus eee pc top case cracked
If it still works then just put a piece of duct tape over the crack.
Jun 28, 2012 | ASUS Eee PC 1005 10 Inch Series 1101HA...
Asus eee pc shuts down when lid closed
Click Start/Control Panel and check the Power Options settings.
Apr 08, 2012 | ASUS Eee 4G Notebook
Hi, Every time I start up my eee pc 1101HA I have an error message : "Asus eee pc acpi service encountered a problem and needs to close..." If I close the pop up comes back immediately. I have...
I found this
you can press the F9 whiles booting up the pc, this will restore the PC to factor with every driver installed, if you need a newer bios or driver, goto www.asus.com and download from there, you can just put all the drivers into a usb stick or sd card and install from there, some of the drivers may need to be extracted first, used winzip or winrar.
BTW
before you install the acpi driver, you need to install the chipset driver first.
I also found this from Bill Yee in Fixya
Quoting from a forum last year discussing how to get rid of your message... "ACPI stands for Advance Configuration and Power Interface, which basically means it lets the OS communicate with the BIOS. This covers things from properly reading battery capacity to hardware features like enabling the Fn keys on your keyboard to work. So it's needed if you want everything to work." Click on the following link to see the discussion thread...
http://forum.eeeuser.com/viewtopic.php?id=86722
The problem can be registry errors, incorrect ACPI drivers or both. You can try the suggested solution of reloading the Asus drivers but you may still get the message due to registry errors. Registry cleaning can by done by Advanced SystemCare Free which is a free utility that can be downloaded from CNet...
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
If all this fails and you can back-up any personal data that you might have on the netbook, a simple solution is on startup to tap F9 to reload the system with its factory-installed image that is on a hidden partition on the netbook's hard disk. Click on the following link to read and follow the steps....
http://www.jabzweb.com/tips-and-tricks/2009/10/how-to-restore-your-asus-eeepc-netbook-to-factory-settings/
Posted on Mar 12, 2011
Asus eee pc acpi service encountered problem and needs to close Google...
Mar 02, 2018 | ASUS 1101HA-MU1X-BK Netbook
How to fit a keypad to asus eee pc 1005ha
Hello, Please follow the bellow link and you can solve
http://netbookitalia.it/asus-eee-pc-1008ha-guida-disassemblaggio-e-upgrade.html http://netbookitalia.it/asus-eee-pc-1101ha-smontaggio-componenti-hardware.html http://cegeekbook.blogspot.com/2009/12/asus-eee-pc-1005hab-tear-down.html http://cegeekbook.blogspot.com/2009/12/asus-1005hab-disassembly-tear-down.html
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi i have a asus eee pc 1005hag and its stuck in hibernation, weather its on battery or ac. it has 2 blue lights on constant. many thanks
when i turn my netbook on the lights turn on but the screen doesnt. I figured out that if i leave it running till the battery goes very low it will turn on.
Jul 22, 2010 | ASUS Eee PC 1005HAG Notebook
ASUS 1101HA-MU1X-BK Netbook Logo
269 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
