Question about Juki DDL-8700
Problems when sewing over heavy jean hems
I use a Juki DDL-8700 for hemming jeans.  When I get to the inseam where the material is super thick, the needle often breaks, bends or the thread breaks. What should I do so this doesn't happen?
Thanks.
  • 4 more comments
  • Denim Doc Mar 29, 2008
    Sewing one thickness at a time wouldn't work as I'm sewing the hem of the jeans back on to the garment.  I need to sew around the opening and when I get to the inseam  the material is so dense that the machine often can't go over it without the problems I mentioned.  I don't know how to adjust the tension.  I know you can but which way do I adjust it, up or down?  I'm wondering if this machine isn't made for such thick material.  Thanks for trying to help.
  • Denim Doc Mar 31, 2008
    Rob, thanks for the tip.  I'll try that and see what happens.  I do sew very slowly over those areas, sometimes I just use the "wheel" instead of actually pressing down on the presser foot.
    I also found out that the machine I'm using is not made for heavy weight material.  It's a commercial one but not for heavy jeans.  Wonder why the company bought that one?  Obviously the ones in charge aren't very knowledgable about sewing.
    I work for a small store that sells jeans, etc. and I do the hemming and small alterations.
    Thanks for you help.  I'll let you know what happens after I try your suggestion.
  • Joanna Sarff Sep 21, 2013
    I use the foot adapter for jeans (costs about $5 at JOanns. No more problems over bulky seams.
  • Anonymous Mar 19, 2014
    I don't know how to move the attachment up that you use for real thick sewing. I can't think of the name of it. It is down and I can't get my regular sewing attachments on.
    juki 8700 thread brakes
  • Anonymous Mar 22, 2014
    can't hem blue jeans, want go over seam
  • 64 Answers
Needle too small u need size 21 needle. screw down the presser foot tension too. if u can't fix it use hand wheel and go thru heavy part by hand.
Posted on Feb 25, 2015
Try (Jean a ma jig) sold in the notions department works for me every time.
JO
Posted on Jul 22, 2008
  • 106 Answers
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Posted on Mar 29, 2008
  • Peter Bradshaw Mar 30, 2008
    From your last comment, as I understand it the thicker areas of the material will not feed through the machine. If this is the case then it is possible the presser foot tension is to high. This is a **** it and see adjustment you need to end up with the presser foot at a pressure that will allow all the thicknesses you are sewing to feed.
    Sit in the normal sewing position, top left of the machine is a raised thick screw with a knurled knob on the top, this adjusts the presser foot tension. Clockwise = more pressure, anti-clockwise = less pressure.
    Try this, lower the presser foot and screw the adjuster clockwise now try lifting the presser foot with your fingers(make sure the power is OFF) eventually the pressure will be so much you will not be able to lift the presser foot. Screw the adjuster anti-clockwise and eventually you will feel the pressure lessen and the foot will be much easier to list.
    Ideally the presser foot should be fairly light on the material with just enough pressure to push it down onto the feed dogs.
    As I said before this is a **** it and see adjustment, eventually you will find a happy medium pressure.
    Another tip is to sew slowly over the thick areas.
    Best of luck
    Rob
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Mar 07, 2015 | Juki DDL-8700
Sewing jeans hems
You need a couple of things. One is to flatten the seams before you try to sew them. One of the best is to spread the hems on a wooden cutting board or simiilar smooth surface and beat the hems flat with a flat faced hammer. This is an official sewing hammer: http://www.fashion-incubator.com/archive/tools_and_supplies/ and it will compress the fabric so it doesn't lift your presser foot up and let the tension off the top thread (which is what's causing your looping problem).
For crossing thick seams, you need a shim to keep the presser foot flat while sewing. These are usually called hump jumpers or jean-a-majigs, and are a couple of bucks. Or you can use a fold of fabric in the same way: http://www.youtube.com/watch?v=WbYenXIDaDk http://www.youtube.com/watch?v=ZKdW_vIZLBo
Alternatively, you can do the jeans hem alteration that pros will charge you more for (because it's "fashionable"), and it's also faster and easier. Often called Euro-hemming: http://www.sewmuchado.com/2011/06/tutorial-how-to-hem-jeans-and-keep-the-original-hem.html
Feb 03, 2014 | Elna Sewing Machines
What juki machine will do lightweight/med weight and heavy jeans
Things to think about are whether or not you want a walking foot machine. Then if you do, decide if you want a needle feed walking foot. (the needle moves in an ovoid fashion, to help pull the material through the feed area.
Juki is a wonderful manufacturer but there are quality machines out there that are just as nice. Check out leathermachineco.com and look at their cobra 18 or cobra 17. Call Steve and talk to him about what you are looking for. (great service)
Nov 01, 2013 | Juki DDL-8700
How to fix your needle assembly on your sewing machine
Sounds a bit serious, jeans fabric is dense and thick. Many machines struggle especially sewing hem over side seam with 6+ layers. You need jeans needle size 90, 100 or 110. Maybe take in for a service as the needle assembly could be out if time too 10_23_2013_1_43_35_pm.png
Aug 01, 2013 | Sewing Machines
I have a 2011 Juki DDL-8300N. Has always worked fine but while sewing on denim it suddenly seized up and stopped sewing. The needle is in the lowest postion through the jeans. I am unable to turn the
Your needle probably bent and got jammed. clip threads top and bottom of the fabric and remove... then get in the bobbin area and look for issues.
Sep 30, 2012 | Juki DDL-8300
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Im trying to hem a pair of jeans when i start it jams up im using a number 16 needle ive checked everything twice ive even called the help number and they couldnt help me i just dont understand what the...
If you think its the way the material is being moved, I would check the pressure on the presser foot. On my machine, there a knob with 1,2,3 to adjust, its vertically above the foot on the top of the machine(Check you manual). Sometimes the jeans hem is just too thick on the side seam. I just skip that part, or move the needle through that part by using my hand on the wheel, so the stitsches look ok, but it should do the rest of the hem fine. Try the thinnest part of the hem first; good luck
Sep 14, 2010 | Kenmore 12912
Can i raise height of presser foot as material is too thick to fit underneath
Not unless the model you are using has more than one height adjustment. This would be addressed in the instruction manual for the machine.
If you raise the heigth of the presser foot too much, the tension control will open and the thread will not form a proper stitch - you will get a loopy stitch that will not hold.
Intersecting seams where you may have 8 layers of fabric can be flatten somewhat with a nylon hammer, or lay a cloth over the seam and use a regular hammer.
I use this when hemming jeans - the flat-feld seams are super thick when turned under for hemming.
Use a longer stitch length when sewing thick fabrics.
Make a sample, replicating what you will be sewing to test techniques and adjustments to the machine before sewing your project.
Feb 22, 2010 | Janome Sewing Machines
Bottom thread is loose and loopy
I would use a denim needle, these are blue coated to slide through the fibres, usually in size 100. But the looping is more about the weight of the seam, ie thickness. Also aremyou trying to use thick yellow jeans thread on the outside and normal thread inside? This is difficult to achieve as the thick yellow thread wont go through needle, you need to use it on the bobbin and sew right side down. I have never had much success with jeans hems on my Japanese machine and usually end up using my industrial Singer to do it. You can try usinf a seam jumper Sometimes called a jeans-a-ma-jig, this helps give leaverage to the feed dogs as you approach the side seams. Also, belt the seams flat with a hammer first.
Jan 18, 2010 | Elna Heirloom Edition 6005
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
Juki DDL-8700 Logo
776 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
