Question about MTX Thunder 6152 Car Audio Amplifier
Mtx thunder 6152 is getting way to hot and shuts its self off when it get really hot
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
Posted on May 13, 2010
What other MTX Thunder amplifier can i hook up with a MTX Thunder 6152 amplifier??
Not sure what you are trying to do, but you don't hook up one amplifier to another. You can pick any brand or model amp to drive other speakers than the ones that you are driving with the 6152. Just consider the power needed to push the speakers at the impedance they are rated(and hooked up)at. Look at the owners manual to determine if you need another amp. Hope that helps a little.
Apr 16, 2014 | Car Audio & Video
Whattx thunder amp would or can go with Mtx thunder 6152 amp?
I can see were you would need the amp to be compatible with the deck but with another amp? the amp is amplifying a specific channel, front or rear speakers and for base only when the deck has a subwoofer pre out built into it. as for compatibility between the amps it would all depend on the sound you want and location and size of speakes will also play a part in that.
Mar 01, 2014 | Car Audio & Video
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
Is the MTX thunder 6152 r capable of 1ohm
its capable of a minimum of 2 ohms; the sticker on the bottom should say
Jan 22, 2011 | MTX Thunder 6152 Car Audio Amplifier
When i try to hook up amp no lights turn on.im pretty sure it works.how can u tell if its burnt up
first thing to do is smell it, second thing to do is to take the bottom covor off to visually check for damage, third is to bench test it with a car batter, a regualar 4 ohm speaker that you know works, and a cd player with rcas going into the amplifer, this is the best way, then if it works on the bench, it must be something with your wiring, bad ground, loose battery clamp, etc.
Aug 09, 2010 | MTX Thunder 6152 Car Audio Amplifier
I just got a mtx thunder 6152 amp got it all hooked up its working but red light is on, should it be red or green?
http://www.mtx.com/caraudio/archive/NDM185.pdf .... go to this link for more help, it is the owners manual
Apr 24, 2010 | MTX Thunder 6152 Car Audio Amplifier
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
Amp not working need repair
You should open the amp and check if you've popped a transistor. It could also be that you've blown a relay... which really sucks lol
Dec 11, 2007 | MTX Thunder 81000D Car Audio Amplifier
Sond gone
sounds like an internal problem. first disconnect all spks from amp, then switch on head unit and check if amp turns on (LED ON?) then feel the heatsink, if heatsink gets terribly hot then amp has internal fault. if amp doesnt get hot then try connecting a single working speaker to each channel separately, it may occur that one channel is faulty only. amps can shut down if the speaker/s is faulty as well, check all speakers and spk wires for shorts before taking amp in for repair. cheers
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
MTX Thunder 6152 Car Audio Amplifier Logo
161 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
