Question about Roper Washing Machines
My washer will fill and then nothing else,help
    Top Expert:
  • Roper Master
  • 76,649 Answers
Make and model number of the washer, is it a top loader? does it have a mechanical timer control, this would be a knob u turn? if this is an electronic control do u have any codes flashing?
Posted on May 13, 2010
  • smoky2patch May 13, 2010
    it has a timer that is activated by a coin slide bar. it is a top loader built in 2004
  • yadayada
    yadayada May 13, 2010
    You will need to replace the timer control.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First you did not mention the manufacturers name and model no# for your washer for exact information. However, this occurs mainly due to things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do accept the solution if the issue is resolved or post a comment with the manufacturers name and model no# for your washer for further assistance.
Thanks
Rylee
  • 2 more comments
    This isa Roper Heavy duty Washer / coin operated. the washer actually fills with water but doesn't continue.
    Bob
  • Rylee Smith
    Rylee Smith May 13, 2010
    To start with try to clean the lint. You can do it when its in spin lift up the lid and check for lint there. If still its not resolved and you hear a humm/buzz sound then its the motor that has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    I just tryed it again. I lower the hose to empty the tub. Then I rasied the hose and started a new cycle. Again filled with water and it doesn't start washing, what do you think?
  • Rylee Smith
    As I said earlier it can be the hose and/or the motor thats not running as the washer just fills and wont do anything else. Please do accept the solution
    Thanks
    Rylee
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
My kenmore 400 washer fills but nothing else
Lid switch is still most likely the problem. Are you able to unplug washer from wall and check the wire connected to the switch.
Aug 28, 2009 | Washing Machines
My Maytag Washer Model A606 just quit working. No
The small fuse will prevent water from filling if it is blown. .3 amp
Jun 10, 2009 | Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer help
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Washing Machines Logo
26 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
