Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan 18" chainsaw. Dispite my best efforts to tighten the chain, it keeps slipping off of the bar. I can use it for about 30 seconds, then the chain slips off.
  • dontbother10
    dontbother10 May 14, 2010
    Very good Mr D. Hold the nose of the bar elevated when adjusting and tightening the bar nuts. Is it a tool-less tension set-up? The failure rate of these is quite high. Lou
    Brigadier General:
  • 4,088 Answers
Make sure the chain brake is off (pull it toward you), then remove the bar mounting nut(s)/bolt(s) and the remove the side cover, bar, and chain. Clean the oil passages in the rear of the bar including two small passages that run from the larger holes out to the chain groove on each side. Clean the entire chain groove and make sure the end sprocket turns freely and is well oiled. Clean the engine face where the bar fits, then start the engine. Oil should ooze out of a small port in the engine case. If ok, then lay out the chain so that it can be inspected for bent links, dry/sticking joints, or missing/badly worn drive teeth. Inspect the sprocket on the clutch outer drum component for wear or damaged teeth. Make sure the pitch of the chain teeth match those of the drive sprocket (is this a new chain?). Check the hub bearing of the clutch drum for obvious wear. If all looks good, fit the chain around the clutch sprocket, then slip the bar into the the engine mounting space and work the chain over the entire bar. When setting the outer cover, make sure the adjuster tang fits into the related bar hole, then attach the clamp nut(s)/bolt(s), run up finger tight. Use the adjuster to set the chain tension--it should just pull the lower part of the chain up to the bar plus a little more. Check that you can move the chain by hand without any binding, then tighten the clamp bolts/nuts firmly. Recheck that the chain is properly tensioned. If not, re-loosen the clamp fasteners and re-tension the chain. When the clamp fasteners are tight, the tension must be rechecked. Hope this long-winded response helps!
Posted on May 14, 2010
The chain has come off. I put it back but it is too loose. How do I tighten it
Should be a screw next to the bar. you can tighten it and it will tighten the chain. Keep in mind that the 2 bolts holding the bar and cover in place have to be loose to do this.
May 27, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
18" chain keeps slipping while trying to cut oleanders, Is there some way to make the chain more stable?
You need to adjust your bar & chain tension as described in your user manual. Here is the location if you have misplaced: https://images.worx.com/en-us/manuals/WG300%20WG303%20WG304.pdf.
Basically you will take the "large knob" cover off, tighten the bar tension and put the cover back on. This will provide you with additional adjustment tension as needed.
Mar 23, 2015 | Worx WG304 - 18" Electric Chainsaw
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Adjusting an electric chainsaw bar and chain
UN PLUG FIRST THEN Loosen the bar and lift with the chain then tighten with a screwdriver the screw is normally found at the front beside the bar re tighten the bar the chain should not be over tight check chain oil
Jul 17, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
Chain dowsn't stay tight
Between the chain bar and the body there is an adjusting screw, if the adjusting screw is stripped it will not pull on the chain bar to tighten the chain.
procedure for tightening chain. loosen the chain guard nuts, tighten the bar adjusting screw by turning to the right or clockwise, the chain has to roll freely around the bar but not bind. check with gloves or rag, don't use bare hands to avoid accidents. once chain is adjusted, tighten the chain guard nuts. good luck!
Oct 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a 14" Poulan
Take off nut, remove bar and chain, turn adjusting screw counter clockwise, replace bar and chain tighten screw, replace nut.
Aug 31, 2011 | Poulan 14" Chainsaw
Chain has a rattling noise but has lots of oil.
I would start by closely inspecting the chain bar. Make sure it is not warped,bent,or twisted even slightly.Look for any dents or burrs in guide channel and make sure gear teeth on the end are in good shape. Slight burrs can be filed smooth with small flat file and minor dents canbe straightened with needle nose pliers then touched up with a file.If you find any problems other then minor replace the bar.
Check chain over carefully making sure that all drive tangs are in good shape,not bent,chipped,or exccessivily worn.
Most importantly make sure your chain is properly tensioned. The way I do it is once I've made sure the chain and bar are in good shape I tighten the chain snugly with saw at operating temperature. Check to make sure chain rotates freely and restart saw and run at high R.P.M.s for 30-45 seconds. Shut off saw and wearing gloves grip chain at mid point of bar and lift saw. I try to get enough clearance to slip a nickle between bottom of drive tang and top of bar. tighten bar retaining nuts and run saw for several mins. and check again. Hope this helps you and thanks.
Dec 21, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do I tighten my chain? its too loose and keeps falling off.
Mike's answer might do it. My saw has a feature in the Chain Bar to turn right or left to move the Bar in or out. Loosen those same nut Mike wrote about, but now turn the Bar Feature (gear) to adjust, and then tighten the two nuts.
Jun 10, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
Mar 25, 2009 | Poulan PP4218AV 18" Chain Saw
Chain slips off bar
I would suggest adjusting the tension and cleaning and debris along the chain path (guide bar).
Here's the manual for Poulan PP4218AV =>
http://72.3.225.179/manuals/165555e.pdf
Look at page 6-7 for instructions to adjust the chain tension and page 16 for cleaning the guide bar.
Here's the link to other Poulan Products =>
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Jan 03, 2009 | Poulan PP4218AV 18" Chain Saw
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
291 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
