Question about Mtd 25B-520D200 CA Gas Lawn Edger
1o years old serviced regulary. home use only . no problems until this spring . smokes a lot, runs ok. Problem?
  • 61 Answers
Sounds like an oil ring has sized up or is just plain wore out.
Posted on May 16, 2010
Recently had my 2003 VW golf serviced (engine flush & oil change). It was running well before the service but on the way home after the service it began blowing white oily smoke everywhere. We took...
I had a similar experience with a 1970 Plymouth Duster, at 10 years old (1980) I flushed the engine and started running a little bit higher detergent oil and it also started smoking as you described,turned out with the engine as clean as it got the clearances of different internal oil retaining parts such as valve guides and piston rings were slightly bigger causing my engine to smoke,
Feb 02, 2014 | Cars & Trucks
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Line trimmer starts and runs well until it gets hot. As soon as throttle let off dies and won't restart until cools down. Less than one year old.
If you are mixing your gas and oil than make sure the ratio is correct, to much fuel and you will run hot, to much oil and you will smoke a lot. Also check spark plug gap that could make machine run hotter than it should be. Make sure engine cooling fins are free of dirt and debris. If it's really less than one year old and if problem persists and you still have heat issue take it back to where you purchased and have them check it out or give you a replacement, a new machine should not run in this manner could be a lemon, it happens. Good Luck...
Aug 30, 2011 | Garden
I have a 2 year old Craftsman Professional Series 24hp, 42" lawn Tractor, PYT series. My problem is that it is very hard to start. Battery is fully charged, new sparkies, changed oil, Takes 4-5...
Mike I just found your post after answering another post. If you still need help I can help you but need to know your ENGINE model number. (Engine brand too please) What your describing is usually caused by valve seats that are caked with carbon. The puff of white smoke you see can be caused by valve stem seals or the piston oil rings. I would not be too concerned about the puff of smoke unless you really lose a lot of power. Often you can remove the cylinder head and use valve grinding compound to re-seat / clean the valve seats. Sadly you have to remove / unlatch the sprong keepers of the valves to do this. It isn't hard but without the first hand knowledge of how the spring keepers are installed it can be very frustrating. Again engine model number please and I can probably get youa link to an on-line service manual that you can use. Not sure why no one answered your question before but.. I am ready to help you now.
Thanks, Kelly
Dec 17, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Water does not turn on. It is ok in sink area...it runs out.
You have 1 of 2 problems on this 35 year old DW...
1. The water solenoid is out.....need replacing.
2. The timer is going bad (has gone bad)...needs replacing....what happens over the years...with timers is that the teeth wear out , break,, wear down, and will not engage specific functions of the dishwasher as in activating the water solenoid. The odds are these parts will be cheap...but having been in the industry for 35 years...I have found that often when you install a new part in an old unit ....it places a load on all the old parts...that they are not used to...and other parts start to fail...you will probably be better off buying a new one....hopefully (and probably) the last you will ever need since you only use it once a week.
I hope this helped thanks ...the Fang.
Mar 27, 2009 | GE Dishwashers
Won't run with cover down.
is there a safty switch on the door, if there is check that first
Feb 01, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fan turns on starts blowing and a lot of smoke.
when you start it the smoke starts wright away it is not getting the right air flow takethe top part off and started see what it does if it stays running try to ajst. the fens ok .
Dec 26, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
I have GE Madellion 870 Washing machine I guess I have motor problem motor stopr after smoke Now Motor spins for few second then stops after 15~ 20 minutes, it will run again for few seconds if my...
Hello ashankhan,
huuum,happy to assist you!
You said,
motor stops after smoke
if my motor burned then why it still runs for few seconds.
The motor is shot and it still works until it heats up, and then it binds up after it over heats!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Sep 18, 2008 | Dishwashers
Mtd 25B-520D200 CA Gas Lawn Edger Logo
44 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
