Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No picture on tv a brief message before it turns itself off no input signal
When you turn the tv on it gives you  message that there is no input signal but the audio works, The tv turns itself 0ff in about 20 seconds.
  • cripps Mar 29, 2008
    I cannot not access the menu because when I push the menu button it turns the tv off. The cables are fine because we have hooked another tv up on the cable and it works fine. i just get a blank screen with the message "no input siganl" then the tv automatically turns itself off. I cannot access any of the menu functions.
  • cripps Mar 30, 2008
    I have already tried thtt,
    Genius:
  • 3,587 Answers
Check cables first...and then go to menu to assess if the unit itself is responsible for.
Posted on Mar 29, 2008
  • Patrick Michaels
    Patrick Michaels Mar 29, 2008
    ok...thanks for that feedback..now, turn off the set, let it rest for around 30 minutes(to deep discharge the voltage inside) and try it again..
  • Patrick Michaels
    Patrick Michaels Mar 30, 2008
    ok..so reset is done...and the cables are good...and still no input signal showing..only answer for that is the video board inside. You up to cracking this puppy open, and replacing the board?
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
Olevia 242 TV.... No picture or sound!!!
A blue screen usually is present if no signal is connected to the set---hook a DVD up to one of the rear inputs--select that input and see if have picture and sound.
If that works connect cable or antenna to set and select that input
NO signal is like no gas in car---it will not run.
Mar 22, 2012 | Televison & Video
No signal on tv
Your Samsung has an Input Source button on the remote. If you are getting a "No Signal" message, you either have no cable, dish, antenna, or HDMI input to the television or have the wrong source selected. With the television turned on and/or a cable box, dish etc turned on, select all of your sources until a picture appears.
Jan 17, 2012 | Samsung 403T 40" LCD Monitor
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Loewe 30" tv turns on, message "no signal"
first thing I would do is to make sure your cable box is turned on. if not fixed, make sure you have the correct input. this can be done by viewing all the inputs that the tv has by pressing the input button on your remote until you find a picture. if it is still not working, make sure you have you cable run right. there should be one cable running to the cable box and into the port labeled antenna or input, then anouther labed cable running from the output port to the tv. there might also be a vcr or dvd play inbetween. if that is the case, the cabel running from the cable box should go to the input of the vcr or dvd play and the output line should go to the tv. any equipment inbetween the cable box and tv should be turned on when viewing you cabel tv. you will also have to make sure that any equipment inbetween is running off the cabel input.
Jul 04, 2009 | Loewe Aconda ACO9303 30" TV
TV displays a "no signal message"
is there any picture at all ? if no signal message regardless of any signal input , ur ad board need to be change.
Sep 19, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Apr 15, 2008 | Vizio GV42L 42 in. LCD Television
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
