Question about Samsung Digimax L730 Digital Camera
The picture on my l730 has gone blurry and it wont take a picture whats wrong?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 13, 2010
My canon eos20d wont take picture, when it does it comes out blurry or overexposed, and it gives me error 99 I live in Mexico so there is no canon repair here, what can i do?
It needs to be sent in for repair. Error 99 is a generic error code informing you that there is something wrong. Since when it actually takes photos and they become blurry or overexposed, I assume its you shutter that has gone bad. The shutter must be staying open longer then it should be. The closest Canon repair plant is in Irvine,Ca. Heres the address and number 15955 Alton Parkway, Irvine - (949) 753-4000 . Sorry about you camera, but its most likely cheaper to buy another used one then to repair it. The repair cost will be between $150-250, but you will get a new shutter that should last a while longer.
May 24, 2011 | Canon EOS 20Da Digital Camera
Blurry view
The simplest thing which might have gone wrong is that you mistakenly activated the macro function. Try taking a picture of, say, a flower from a few inches: if it's sharp, you're employing the camera's macro function and need to deactivate it.
I don't recall the DSC having a manual focus setting, but check it out. If you turned it on, you need to manually adjust the focus through the zoom control in order to get sharp pictures (or turn on autofocus, of course).
Otherwise, the auto-focusing software might be at fault. There are several autofocus settings available; try cycling them all and see if the problem is reversible.
If not, either the autofocus parameters are gone awry - I'm afraid the camera'll need servicing - or maybe a dirty lens is causing the autofocus to malfunction, in which case cleaning it would solve the problem. Frankly, it's unlikely - it would take a really cleverly positioned and greasy fingerprint to fool a modern focusing engine. But you might be lucky, and it's worth a check.
May 29, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
My screen shows a blurry picture and it takes a blurry picture. it didnt used to. what is wrong? how do i fix it?
I have the exact same problem. When I was in NY last fall, suddenly my camera would only take blurry pictures. I hadn't changed any settings or anything. I can get halfway decent pictures in Auto mode, but any of the other settings only take blurry pictures. Apparently a lot of people have this problem, but no one knows how to solve it...
Feb 28, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
I pressed format on my Samsung L730 digital camera and have lost the picture from the screen, is there a way i can get them back? I'm devastated!!!
There is only 1 way to recover these files which is to use File Recovery Software. Examples of these are below just choose which you like. THe only thing here is that it is not free.
FILE RECOVERY 1
FILE RECOVERY 2
Sep 06, 2008 | Samsung Digimax L730 Digital Camera
I encountered this issue today while taking a photo of my dog she licked the lens... the LCD screen went all blurry and I was unable to take any photos. The thing kept beeping at me and I was about to throw it in the bin until I had a good look at the lens. As there was a picture coming through on the LCD I knew it wasn't completely stuffed however as the camera couldn't focus an image it gives the unhelpful beeps which apparently translates to clean the lens! So i gave it a clean and presto it was fixed!
Just be careful when u clean it make sure u don't scratch the lens with rough material or use chemicals. Hope it works.
Feb 17, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
91 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
