power supply must b okay but the lead connecting laptop may have gone faulty, try changing it, if this is not the reason then some internal hardware problem
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
ok..when turning it on..hold down F2. to go to set up..and see if that new drive is activated..be careful in there..there are loads of things that can go haywire.
contact to this email adresses;[email protected] insert the bootable disk then if it cant boot contact above email adresse process for solving the problem: insert bootable disk that is ur dos xp or vista disk then the screen will display press any key to boot from cd/dvd press any key then format ur hdd and install fresh new os imp:dont use piracy . piracy also one of the cause of this problem
First off im affraid you cannot totally rely on ANY software with regards to Thermo sensing they are only an indication and can be anywhere from 5 to 25 degreeC out, dont get me wrong generally you can get a good indication but thats the best they can be. Listen for fans kicking in then staying on, keyboard getting warm to hot. If the machine is just cutting out that would suggest power supply either charger fault etc (is the battery fully charged when it happens) or overheating, if its shutting down the first thing i would try is running in safe mode see how it performs, check for any spyware/virus, run Hope helps for now let me know
