Question about JVC KD-G430 CD Player
Jvc car stereo kd-g331 wont function
Power light is on but cant make anything work. there is a cd still inside unit, unable to eject it. not one single button working at all. apparently was working fine until traffic update cut in, then nothing. any suggestions?
SOURCE: cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Posted on Jan 18, 2009
SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Posted on Jan 24, 2009
  • 4 Answers
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
Posted on Mar 01, 2009
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
Unit wont slide down for CD eject ERR 06
cd roller bars are bent ther is no ez fix replace deck
Jul 07, 2010 | JVC KD-SH55 CD Player
JVC KD-G340 Power Problem
Try rewiring it. Yellow to a full time hot 12v and red to an ignition switched 12v
Feb 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-LH300 Wont Work
Clean the parts on the connector between the faceplate and the stereo maybe get dirty
Sep 04, 2008 | JVC Sirius KD-LH300 CD Player
How to connect a amp to a jvc kd-g331 head unit
The JVC-G331 should have an auxilary output on the Back (red & White) run two Stereo RCA cables from this output to the input on the amplifier, then you're ready to go! ;)
Oh yeah, make sure and run the RCA's on the opposite side of the car as the power wire (most likely 4ga) or else you could hear interference.
Jul 18, 2008 | JVC Car Audio & Video
My JVC KD-G331 Cd Player Won't Work In My Clio (X reg)
Hi, did you fix this problem?
I'm having exactly the same issue myself.
Jul 03, 2008 | JVC KD-S6060 CD Player
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
JVC KD-G430 CD Player Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
